跳转到主内容
Acer Aspire One ZG5 Wireless Card Replacement
Doug Gallatin
Doug Gallatin6 其他贡献者
最后更新于 February 9, 2024
5分钟
简单
特色指南
更好的介绍
You will have to remove several screws and a couple of cables on the bottom of the ZG5 to remove or replace the wireless card.
你所需要的
工具
  1. Acer Aspire One ZG5 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • Gently loosen the two Phillips #0 screws in the small panel that covers the wireless card.
    • These screws are built into the panel and aren't meant to be completely removed.
  5. Acer Aspire One ZG5 Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Lift up the panel and remove it from the case.
  6. Acer Aspire One ZG5 Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Disconnect the two antenna cables from the left side of the wireless card.
  7. Acer Aspire One ZG5 Wireless Card Replacement: 步骤 7 中的图像 1,1
    • Remove the single 3.9 mm Phillips #1 screw from the bottom left of the wireless card.
  8. Acer Aspire One ZG5 Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Gently lift up the left side of the wireless card and slide the card out of its socket.
结论
8等其他人完成本指南。
Doug Gallatin
于10/05/10注册
6,337 声望
创作了10篇指南
团队
Cal Poly, Team 7-49, Amido Fall 2010 Cal Poly, Team 7-49, Amido Fall 2010 的会员
CPSU-AMIDO-F10S7G49
5 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 48
总计 23,798
