跳转到主内容
Acer Aspire One D255E Screen Replacement
Brian
Brian 另一个贡献者
最后更新于 September 17, 2019
没有估计
中等
Damaged screens are one of the most common issues that will occur with a computer. While most laptops require the complete disassembly of the computer to replace the screen, the Acer Aspire One D255E requires significantly less work. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The metal spudger is great when you need serious prying power, but the regular black nylon spudger or a plastic opening tool should be used whenever possible.
你所需要的
工具
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  1. Acer Aspire One D255E Screen Replacement, Screen: 步骤 1 中的图像 1,2 Acer Aspire One D255E Screen Replacement, Screen: 步骤 1 中的图像 2,2
    • Using a spudger remove the two screw covers on the front of the computer.
  2. Acer Aspire One D255E Screen Replacement: 步骤 2 中的图像 1,2 Acer Aspire One D255E Screen Replacement: 步骤 2 中的图像 2,2
    • Remove the two 1.2 mm Phillips #1 screws that were located under the screw covers.
  3. Acer Aspire One D255E Screen Replacement: 步骤 3 中的图像 1,1
    • Using a spudger for assistance remove the front panel of the screen.
    • It is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Screen Replacement: 步骤 4 中的图像 1,3 Acer Aspire One D255E Screen Replacement: 步骤 4 中的图像 2,3 Acer Aspire One D255E Screen Replacement: 步骤 4 中的图像 3,3
    • Remove the eight 1.2 mm Phillips #1 screws holding on the screen.
    • There are wires connected to the screen unit. Make sure you do not attempt to pull off the screen just yet!
  5. Acer Aspire One D255E Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully remove the display ribbon cable from the connector.
结论
3等其他人完成本指南。
Brian
于03/19/16注册
1,302 声望
创作了5篇指南
团队
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S16G8
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 30
总计 2,287
