跳转到主内容
Acer Aspire One D255E Keyboard Replacement
Brian
Brian 另一个贡献者
最后更新于 September 16, 2019
没有估计
中等
The keyboard is the most essential input component on a laptop. Though this component is designed to have frequent usage either with old age or bad treatment this component may have to be replaced. You should read through the entire guide before performing the repair and should have all necessary tools readily available. You should also find a safe location to store the various screws taken out of the computer to ensure that they do not get mixed up or lost.
你所需要的
工具
  • Spudger
    Spudger
  1. Acer Aspire One D255E Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Start by removing the battery found on the back of the device.
    • The battery must be removed in order to ensure the device does not have power! Make sure you do not skip this step!
  2. Acer Aspire One D255E Keyboard Replacement: 步骤 2 中的图像 1,2 Acer Aspire One D255E Keyboard Replacement: 步骤 2 中的图像 2,2
    • Using plastic opening tools press down the 6 clips located around the keyboard.
  3. Acer Aspire One D255E Keyboard Replacement: 步骤 3 中的图像 1,3 Acer Aspire One D255E Keyboard Replacement: 步骤 3 中的图像 2,3 Acer Aspire One D255E Keyboard Replacement: 步骤 3 中的图像 3,3
    • Using a plastic opening tool or spudger move the keyboard out of position.
    • There is a thin cable on the backside of the keyboard. Make sure when you move the keyboard out of position you do so slowly to prevent damage to this cable.
    • If you use a spudger it is recommended that you use a plastic spudger to reduce the chance of damaging any internal parts.
  4. Acer Aspire One D255E Keyboard Replacement: 步骤 4 中的图像 1,1
    • Using a spudger gently push the tab on the port forward then pull out the cable.
    • Be careful to do so as gently as possible. You do not want to damage the port.
结论
3等其他人完成本指南。
Brian
于03/19/16注册
1,302 声望
创作了5篇指南
团队
UMass Dartmouth, Team 16-8, Bhusal Spring 2016 UMass Dartmouth, Team 16-8, Bhusal Spring 2016 的会员
UMASSD-BHUSAL-S16S16G8
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 17
过去 7 天: 24
过去 30 天: 26
总计 2,481
