跳转到主内容
Acer Aspire 5100 Fan Replacement
Brad Rollinson
Brad Rollinson13 其他贡献者
最后更新于 November 7, 2022
10分钟
中等
Over time, your Acer Aspire 5100 laptop’s fan may stop working. Laptops without working fans may overheat, damaging internal hardware such as the CPU, hard drive, and motherboard. You may have a broken fan if your laptop regularly feels hot or crashes, your fan makes abnormal or no noise, or your vents lack airflow. If these problems occur, you will need a replacement fan to keep your laptop regulated and running smoothly.
This guide will help you replace your broken fan in four simple steps. Before starting, be sure to unplug your laptop and remove the battery for your personal safety.
你所需要的
配件
工具
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
查看更多...
当你通过这些链接购买商品时,iFixit 会赚取佣金。
  1. Acer Aspire 5100 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Flip the laptop upside-down.
    • Remove the battery as a safety precaution.
    • Remove the four screws attached to the large panel.
  2. Acer Aspire 5100 Fan Replacement: 步骤 2 中的图像 1,1
    • Lift and remove the panel.
  3. Acer Aspire 5100 Fan Replacement: 步骤 3 中的图像 1,1
    • Remove the two screws attached to the fan.
  4. Acer Aspire 5100 Fan Replacement: 步骤 4 中的图像 1,2 Acer Aspire 5100 Fan Replacement: 步骤 4 中的图像 2,2
    • Lift the fan and detach the cable that connects the fan to the motherboard.
    • The fan can break easily. Be careful when removing.
    • When detaching the cable, do not pull on the cable itself. Instead, use a small spudger to detach it at the white section that connects it to the motherboard.
结论
4等其他人完成本指南。
Brad Rollinson
于09/29/10注册
1,113 声望
创作了7篇指南
团队
Cal Poly, Team 14-39, Forte Fall 2010 Cal Poly, Team 14-39, Forte Fall 2010 的会员
CPSU-FORTE-F10S14G39
5 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 34
总计 15,115
