跳转到主内容
加入维修社区 - 创建账户
Acer AL1916 VGA Input Replacement
你所需要的
  1. Acer AL1916 VGA Input Replacement, Stand: 步骤 1 中的图像 1,1
    • Lay the monitor on a flat surface so that the back is facing up.
    询问修复机器人
    添加评论
  2. Acer AL1916 VGA Input Replacement: 步骤 2 中的图像 1,2 Acer AL1916 VGA Input Replacement: 步骤 2 中的图像 2,2
    • Grab the hinge cover with both hands on either side of the stand.
    • Squeeze inwards with your thumbs and fingers and lift up to remove the hinge cover.
    询问修复机器人
    添加评论
  3. Acer AL1916 VGA Input Replacement: 步骤 3 中的图像 1,2 Acer AL1916 VGA Input Replacement: 步骤 3 中的图像 2,2
    • Remove the four 12.1 mm Phillips #2 screws that hold the stand to the monitor.
    • Support the monitor while removing the screws to prevent the monitor from falling.
    • Lift up to detach the stand.
    添加评论
  4. Acer AL1916 VGA Input Replacement, Outer Case: 步骤 4 中的图像 1,2 Acer AL1916 VGA Input Replacement, Outer Case: 步骤 4 中的图像 2,2
    • Remove the five 9.5 mm Phillips #2 screws located around the perimeter of the monitor.
    询问修复机器人
    添加评论
  5. Acer AL1916 VGA Input Replacement: 步骤 5 中的图像 1,3 Acer AL1916 VGA Input Replacement: 步骤 5 中的图像 2,3 Acer AL1916 VGA Input Replacement: 步骤 5 中的图像 3,3
    • Starting at the corner of the monitor, wedge the small plastic opening tool between the back cover and the display bezel.
    • Tilt the plastic opening tool up to separate the back cover from the display bezel.
    • Continue around the perimeter of the monitor until the display bezel comes off.
    • A reasonable amount of force is necessary to detach the back cover from the display bezel.
    询问修复机器人
    添加评论
  6. Acer AL1916 VGA Input Replacement: 步骤 6 中的图像 1,2 Acer AL1916 VGA Input Replacement: 步骤 6 中的图像 2,2
    • Reposition the monitor so that the back is facing up.
    • Grab the corners of the monitor and jiggle them upwards to detach the back cover from the inside of the monitor.
    • Lift the back cover up.
    询问修复机器人
    添加评论
  7. Acer AL1916 VGA Input Replacement, EMI Shield: 步骤 7 中的图像 1,2 Acer AL1916 VGA Input Replacement, EMI Shield: 步骤 7 中的图像 2,2
    • Remove the two 5.7 mm Phillips #2 screws located on either side of the EMI shield.
    询问修复机器人
    添加评论
  8. Acer AL1916 VGA Input Replacement: 步骤 8 中的图像 1,2 Acer AL1916 VGA Input Replacement: 步骤 8 中的图像 2,2
    • Using a nut driver (or if necessary, needle-nose pliers), remove the two nuts on either side of the VGA input.
    询问修复机器人
    添加评论
  9. Acer AL1916 VGA Input Replacement: 步骤 9 中的图像 1,3 Acer AL1916 VGA Input Replacement: 步骤 9 中的图像 2,3 Acer AL1916 VGA Input Replacement: 步骤 9 中的图像 3,3
    • Grab the metal casing by the sides and slide it down towards the bottom of the monitor.
    • Lift up to remove the metal casing.
    • Beware, metal casing is sharp!
    询问修复机器人
    添加评论
  10. Acer AL1916 VGA Input Replacement, Motherboard: 步骤 10 中的图像 1,2 Acer AL1916 VGA Input Replacement, Motherboard: 步骤 10 中的图像 2,2
    • Remove the beige control cable to the left of the VGA input by pulling it up.
    询问修复机器人
    添加评论
  11. Acer AL1916 VGA Input Replacement: 步骤 11 中的图像 1,2 Acer AL1916 VGA Input Replacement: 步骤 11 中的图像 2,2
    • Remove the rainbow-colored power cable by pulling it straight up.
    询问修复机器人
    添加评论
  12. Acer AL1916 VGA Input Replacement: 步骤 12 中的图像 1,2 Acer AL1916 VGA Input Replacement: 步骤 12 中的图像 2,2
    • Remove the display cable located at the top of the motherboard by pulling it out towards the top of the monitor.
    询问修复机器人
    添加评论
  13. Acer AL1916 VGA Input Replacement: 步骤 13 中的图像 1,3 Acer AL1916 VGA Input Replacement: 步骤 13 中的图像 2,3 Acer AL1916 VGA Input Replacement: 步骤 13 中的图像 3,3
    • Remove the three 7.7 mm Phillips #2 screws from the motherboard, and take out the motherboard by lifting it up.
    询问修复机器人
    添加评论
  14. Acer AL1916 VGA Input Replacement, VGA Input: 步骤 14 中的图像 1,2 Acer AL1916 VGA Input Replacement, VGA Input: 步骤 14 中的图像 2,2
    • Set the circuit board down on its own, removed from the rest of the monitor.
    • Flip the circuit board over so that the VGA input is facing upwards.
    询问修复机器人
    添加评论
  15. Acer AL1916 VGA Input Replacement: 步骤 15 中的图像 1,3 Acer AL1916 VGA Input Replacement: 步骤 15 中的图像 2,3 Acer AL1916 VGA Input Replacement: 步骤 15 中的图像 3,3
    • Using the soldering iron, desolder the VGA input at the indicated locations.
    • Solder the new VGA input into the circuit board at the same locations.
    • Click here for more information on component-level soldering.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
Cal Poly, Team 20-26, Maness Fall 2011 Cal Poly, Team 20-26, Maness Fall 2011 的会员
CPSU-MANESS-F11S20G26
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 50
总计 3,823
