跳转到主内容
Accessing Nokia 3100b Vibrating Unit
你所需要的
  1. Accessing Nokia 3100b Vibrating Unit, Battery: 步骤 1 中的图像 1,1
    • Make sure your phone is turned off.
  2. Accessing Nokia 3100b Vibrating Unit: 步骤 2 中的图像 1,1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Accessing Nokia 3100b Vibrating Unit, SIM Card: 步骤 3 中的图像 1,1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Accessing Nokia 3100b Vibrating Unit: 步骤 4 中的图像 1,1
    • Retrieve your SIM card.
  5. Accessing Nokia 3100b Vibrating Unit, Vibrating Unit: 步骤 5 中的图像 1,1
    • Separate the front cover from the base of the phone.
    • Set the front cover, as indicated, aside.
  6. Accessing Nokia 3100b Vibrating Unit: 步骤 6 中的图像 1,1
    • Remove the screws indicated using a T6 Torx screwdriver.
    • Remove them in the order of the colors of the rainbow. (Red, Orange, Yellow, Green, Blue, Purple).
  7. Accessing Nokia 3100b Vibrating Unit: 步骤 7 中的图像 1,1
    • Separate the screen assembly from the base of the phone.
    • Set the screen assembly, as indicated, aside.
  8. Accessing Nokia 3100b Vibrating Unit: 步骤 8 中的图像 1,1
    • The vibrating unit can now be accessed. Note its location in the phone.
  9. Accessing Nokia 3100b Vibrating Unit: 步骤 9 中的图像 1,1
    • The vibrating unit is held in place by friction. Access the bottom of the unit and push upward to release it from the base.
  10. Accessing Nokia 3100b Vibrating Unit: 步骤 10 中的图像 1,1
    • The vibrating unit is now removed.
结论
另外一个人完成了本指南。
Sterling Fuentes
于04/09/10注册
130 声望
创作了8篇指南
团队
Cal Poly, Team 29-64, Johann Spring 2010 Cal Poly, Team 29-64, Johann Spring 2010 的会员
CPSU-JOHANN-S10S29G64
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,722
