跳转到主内容
加入维修社区 - 创建账户
AYL SoundFit Motherboard Replacement
你所需要的
    1. AYL SoundFit Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
      • Unscrew the four hex screws on the top of the device using a 2.5mm hex screwdriver.
      询问修复机器人
      添加评论
    2. AYL SoundFit Motherboard Replacement: 步骤 2 中的图像 1,1
      • Place a spudger between the black plastic cover and the green case.
      • Remove the black cover away from the main casing and remove the cover.
      询问修复机器人
      添加评论
    3. AYL SoundFit Motherboard Replacement: 步骤 3 中的图像 1,1
      • Place the spudger tool between the black housing, which contains the woofer, and the outer rubber casing.
      • Remove the housing away from the body to reveal the motherboard, speaker, and battery.
      询问修复机器人
      添加评论
    4. AYL SoundFit Motherboard Replacement: 步骤 4 中的图像 1,2 AYL SoundFit Motherboard Replacement: 步骤 4 中的图像 2,2
      • Remove the two Phillips screws which hold its battery casing on the housing using a PH00 Phillips screwdriver.
      • Remove the battery case to reveal the battery.
      询问修复机器人
      添加评论
    5. AYL SoundFit Motherboard Replacement: 步骤 5 中的图像 1,1
      • Using a soldering iron, heat up and remove both the positive and negative battery contacts from the motherboard.
      询问修复机器人
      添加评论
    6. AYL SoundFit Motherboard Replacement: 步骤 6 中的图像 1,3 AYL SoundFit Motherboard Replacement: 步骤 6 中的图像 2,3 AYL SoundFit Motherboard Replacement: 步骤 6 中的图像 3,3
      • Remove all three Phillips screws which holds the motherboard to the base using a PH00 Phillips screwdriver.
      • The motherboard can now be wiggled free from the base.
      添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
john
于03/10/16注册
171 声望
撰写一个指南
团队
IUPUI, Team 3-3, Harley Spring 2016 IUPUI, Team 3-3, Harley Spring 2016 的会员
IUPUI-HARLEY-S16S3G3
4 名成员
创作了10篇指南
3指南评论
Where do u get a new motherboard at?
calvinsmith522 - 回复 分享
Anybody know where to get a motherboard?
David Whitman - 回复 分享
Where do I get a motherboard?
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 28
总计 2,037
