跳转到主内容
加入维修社区 - 创建账户
ASUS ROG Raikiri Pro Battery Replacement
你所需要的
  1. ASUS ROG Raikiri Pro Battery Replacement, Battery: 步骤 1 中的图像 1,3 ASUS ROG Raikiri Pro Battery Replacement, Battery: 步骤 1 中的图像 2,3 ASUS ROG Raikiri Pro Battery Replacement, Battery: 步骤 1 中的图像 3,3
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    询问修复机器人
    添加评论
  2. ASUS ROG Raikiri Pro Battery Replacement: 步骤 2 中的图像 1,3 ASUS ROG Raikiri Pro Battery Replacement: 步骤 2 中的图像 2,3 ASUS ROG Raikiri Pro Battery Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    询问修复机器人
    添加评论
  3. ASUS ROG Raikiri Pro Battery Replacement: 步骤 3 中的图像 1,2 ASUS ROG Raikiri Pro Battery Replacement: 步骤 3 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    询问修复机器人
    添加评论
  4. ASUS ROG Raikiri Pro Battery Replacement: 步骤 4 中的图像 1,2 ASUS ROG Raikiri Pro Battery Replacement: 步骤 4 中的图像 2,2
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    询问修复机器人
    添加评论
  5. ASUS ROG Raikiri Pro Battery Replacement: 步骤 5 中的图像 1,2 ASUS ROG Raikiri Pro Battery Replacement: 步骤 5 中的图像 2,2
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    询问修复机器人
    添加评论
  6. ASUS ROG Raikiri Pro Battery Replacement: 步骤 6 中的图像 1,2 ASUS ROG Raikiri Pro Battery Replacement: 步骤 6 中的图像 2,2
    • Use a spudger to carefully remove the board and left rumble motor.
    询问修复机器人
    添加评论
  7. ASUS ROG Raikiri Pro Battery Replacement: 步骤 7 中的图像 1,2 ASUS ROG Raikiri Pro Battery Replacement: 步骤 7 中的图像 2,2
    询问修复机器人
    添加评论
  8. ASUS ROG Raikiri Pro Battery Replacement: 步骤 8 中的图像 1,1
    • Gently remove the battery from its enclosure.
    询问修复机器人
    添加评论
结论
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
取消:我没有完成这个指南。
另外一个人完成了本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 10
过去 30 天: 66
总计 849
