跳转到主内容
加入维修社区 - 创建账户
ASUS Q405U Battery Replacement
你所需要的
  1. ASUS Q405U Battery Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
    询问修复机器人
    添加评论
  2. ASUS Q405U Battery Replacement: 步骤 2 中的图像 1,1
    • Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
    询问修复机器人
    添加评论
  3. ASUS Q405U Battery Replacement: 步骤 3 中的图像 1,3 ASUS Q405U Battery Replacement: 步骤 3 中的图像 2,3 ASUS Q405U Battery Replacement: 步骤 3 中的图像 3,3
    • Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
    询问修复机器人
    添加评论
  4. ASUS Q405U Battery Replacement: 步骤 4 中的图像 1,2 ASUS Q405U Battery Replacement: 步骤 4 中的图像 2,2
    • OPTIONAL: Additional pictures to demonstrate moving keyboard out of the way without detaching connections.
    • Lift the ribbon cable with gentle pressure, pry the ribbon away from the motherboard on the right side, then the left, then the center, prying away only a little triangle of tape at a time, applying gentle upward pressure to the tape while you loosen and pry.
    • Once you have enough slack in the three ribbons that hold the keyboard down too tightly, lift the front of the keyboard and twist counterclockwise to produce enough room to reach the screws securing the hard drive with your screwdriver.
    询问修复机器人
    添加评论
  5. ASUS Q405U Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
    询问修复机器人
    添加评论
  6. ASUS Q405U Battery Replacement: 步骤 6 中的图像 1,1
    • Once all screws are removed, lift the battery out from the base of the computer.
    询问修复机器人
    添加评论
结论
For optimal performance, after completing this guide, calibrate your newly installed battery.
取消:我没有完成这个指南。
2等其他人完成本指南。
团队
UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 UMass Dartmouth, Team 2-8, Sinclaire Fall 2021 的会员
UMASSD-SINCLAIRE-F21S2G8
4 名成员
创作了5篇指南
1指南评论
I had to remove two other screws from right side where the hard drive is and an extra screw from Step 4 picture. Also I had to remove the wifi card (or the antennas)
Larry Bishop - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 46
总计 2,758
