跳转到主内容
ASUS PadFone X Station Power and Volume Contacts Replacement
Jessica
Jessica5 其他贡献者
最后更新于 May 7, 2024
5 - 10 分钟
简单
更好的介绍
你所需要的
工具
  1. ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: 步骤 1 中的图像 1,2 ASUS PadFone X Station Power and Volume Contacts Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Power and Volume Contacts Replacement, Locate CON1501: 步骤 2 中的图像 1,1
    • Locate CON1501
    • CON1501 will be visible underneath the contacts. You can readily see this if you look for the orange strip of film in the top right corner of the back of the Asus Padfone X Docking Station.
  3. ASUS PadFone X Station Power and Volume Contacts Replacement, Remove (1) phillips screw.: 步骤 3 中的图像 1,1
    • Remove (1) phillips screw
    • Using a +PH00 Phillips screwdriver , you will unscrew the Phillips screw in the top right corner of the back of the ASUS Padfone X docking station.
    • To unscrew the Phillips screw simply position the screwdriver inside of the screw, then rotate it counter-clockwise until the screw is fully removed from the docking station.
  4. ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: 步骤 4 中的图像 1,2 ASUS PadFone X Station Power and Volume Contacts Replacement, Disconnect ribbon from CON1510: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    • Disconnect ribbon from CON1510
    • To disconnect the ribbon from CON1510, use a pair of tweezers and gently lift the connect up and back from the device.
  5. ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 步骤 5 中的图像 1,3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 步骤 5 中的图像 2,3 ASUS PadFone X Station Power and Volume Contacts Replacement, Lift contacts off device: 步骤 5 中的图像 3,3
    • Now that the contacts are no longer attached, you can use either tweezers or your fingers to grasp and lift contacts vertically off of the device.
结论
2等其他人完成本指南。
Jessica
于10/07/14注册
150 声望
撰写一个指南
团队
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S7G4
4 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 566
