跳转到主内容
ASUS PadFone X Station Battery Replacement
Paul Wagner
Paul Wagner3 其他贡献者
最后更新于 May 7, 2024
5 - 10 分钟
简单
更好的介绍
你所需要的
工具
查看更多...
  1. ASUS PadFone X Station Battery Replacement, Back Cover: 步骤 1 中的图像 1,2 ASUS PadFone X Station Battery Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using the plastic opening tools, insert it into the edge and pry open.
    • Use hands to help pull the back off from the front if needed.
  2. ASUS PadFone X Station Battery Replacement, Finding the Battery: 步骤 2 中的图像 1,1
    • Locate 4600mAh Battery
  3. ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: 步骤 3 中的图像 1,2 ASUS PadFone X Station Battery Replacement, Removing the Protective Cover: 步骤 3 中的图像 2,2
    在这个步骤中使用的工具:
    • Locate (+) and (-) battery terminals
    • Trace black, white, red, and yellow wires to connection on motherboard
    • Remove protective plastic cover with tweezers
  4. ASUS PadFone X Station Battery Replacement, Disconnecting the Ribbon: 步骤 4 中的图像 1,1
    • Disconnect connect ribbon by gently pulling with fingers
    • Ensure the ribbon does not touch metallic items (This may short out battery and cause an explosion)
  5. ASUS PadFone X Station Battery Replacement, Removing the Screws: 步骤 5 中的图像 1,2 ASUS PadFone X Station Battery Replacement, Removing the Screws: 步骤 5 中的图像 2,2
    • Remove (4) screws
  6. ASUS PadFone X Station Battery Replacement, Taking out the Battery: 步骤 6 中的图像 1,3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: 步骤 6 中的图像 2,3 ASUS PadFone X Station Battery Replacement, Taking out the Battery: 步骤 6 中的图像 3,3
    • Gently pry battery off glued surface
    • Use of a plastic opening tools and a spudger are necessary
结论
5等其他人完成本指南。
Paul Wagner
于10/07/14注册
545 声望
创作了2篇指南
团队
USF Tampa, Team 7-4, Leahy Fall 2014 USF Tampa, Team 7-4, Leahy Fall 2014 的会员
USFT-LEAHY-F14S7G4
4 名成员
创作了8篇指南
3指南评论
where can i find a battery for that station pls?
francidorio - 回复
Hello dear. Thanks for the tutorial on how to change the Padfone X tablet battery.
I have the Padfone x station without the cell phone because unfortunately my students have stolen it from me in the classroom while attending a mother (in Cordoba, Argentina).
I would like to know, then, if I could adapt an Asus cell phone model by changing the slot in the cell phone and / or in the tablet station in the back where both devices are embedded, so, what kind of spare parts should buy, and with which name to ask.
Since a thousand and one thanks. Best regards from Cordoba, Argentina.
Clara.
calejanmm - 回复
The proper battery for this unit is C11P1323.
acg - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 3,712
