ASUS GL752VW-DH74 Screen Replacement
简介
转到步骤 1This guide demostrates the removal of the Asus GL752VW-DH74 display. Make sure that the laptop is unplugged before utilizing this guide.
6等其他人完成本指南。
6条评论
Followed your tutorial and replaced my laptop screen successfully, thanks!
3 stars at best. If I did not have any experience dealing with hardware replacement - and mine is only desktop - I would have been hard pressed to complete the screen replacement, if at all. I can't imagine a single person I know who had never kicked around on the internals of a computer that could have done this. You leave out incredibly important steps and kiddos to the few comments that corrected you on the screws that needed removal. You could have told us to remove the screen cable from the back of the screen and not the motherboard. You also assumed people had special tools at their disposal such as a hinge remover tool, or case separator tool. You should have advised people to take pictures before each step so that when reassembling they could refer to how it looked before they pulled this cable or that. All in all, thanks, but a sloppy job.
EDIT: I see that you did list the told needed at the beginning so I have to retract that issue and can still only give you 3 stars. You make to many assumptions about the technical ability of the reader. Also, I may be wrong but I do not believe the screen cable is a SATA connection.
Also, tell people to take care in storing and organizing the different screws, where they came from, store separately, etc. For instance I took a unused plastic container for a variety of screws with different segments to hold various hardware of different types and labeled each as I removed them.
