跳转到主内容
加入维修社区 - 创建账户
ASUS D550MA-DS01 Keyboard Module Replacement
你所需要的
    1. ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: 步骤 1 中的图像 1,2 ASUS D550MA-DS01 Keyboard Module Replacement, Keyboard Module: 步骤 1 中的图像 2,2
      • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
      • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
      询问修复机器人
      添加评论
    2. ASUS D550MA-DS01 Keyboard Module Replacement: 步骤 2 中的图像 1,1
      • Turn the laptop over and open the display.
      • Insert the flat edge of the spudger into the crease of the keyboard cover.
      • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
      • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
      询问修复机器人
      添加评论
    3. ASUS D550MA-DS01 Keyboard Module Replacement: 步骤 3 中的图像 1,2 ASUS D550MA-DS01 Keyboard Module Replacement: 步骤 3 中的图像 2,2
      • Make sure that the entire cover has been released from the plastic clips.
      • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
      • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
      添加评论
    4. ASUS D550MA-DS01 Keyboard Module Replacement: 步骤 4 中的图像 1,1
      • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
      • Disconnect the three data cables from the motherboard.
      • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
      询问修复机器人
      添加评论
    5. ASUS D550MA-DS01 Keyboard Module Replacement: 步骤 5 中的图像 1,1
      • Remove the fully disconnected keyboard module from the laptop.
      添加评论
结论
取消:我没有完成这个指南。
4等其他人完成本指南。
redacted
于09/15/15注册
566 声望
创作了3篇指南
3指南评论
Does anybody knows how to remove the keyboard from the keyboard module??I want to replace the keyboard not the whole piece
mfq1979 - 回复 分享
where can I get a keyboard replacement
Kwame Mitchell - 回复 分享
http://www.newegg.com
Replacement Keyboard N2840 s/n EBNOCX62041047D sold by, Alpha Vr Electronics, 860-755-2309 ext. 22831 $20.99
Eugene Bohrmann - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 44
总计 2,846
