跳转到主内容
加入维修社区 - 创建账户
ASUS D550MA-DS01 DVD Drive Replacement
你所需要的
  1. ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: 步骤 1 中的图像 1,2 ASUS D550MA-DS01 DVD Drive Replacement, Keyboard Module: 步骤 1 中的图像 2,2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Use a Philips #1 screwdriver to remove the nine screws from the back cover.
    询问修复机器人
    添加评论
  2. ASUS D550MA-DS01 DVD Drive Replacement: 步骤 2 中的图像 1,1
    • Turn the laptop over and open the display.
    • Insert the flat edge of the spudger into the crease of the keyboard cover.
    • While the spudger is in the crease, carefully pry open the casing by sliding the spudger along the edge.
    • Do not use excessive force to pry open the lid. You should hear each plastic clip snap open as you run the spudger along the edge.
    询问修复机器人
    添加评论
  3. ASUS D550MA-DS01 DVD Drive Replacement: 步骤 3 中的图像 1,2 ASUS D550MA-DS01 DVD Drive Replacement: 步骤 3 中的图像 2,2
    • Make sure that the entire cover has been released from the plastic clips.
    • Slowly lift the cover open from the front of the laptop, but do not completely remove it.
    • Note the locations of the three white and blue data cables connecting to the keyboard to the computer's main board.
    添加评论
  4. ASUS D550MA-DS01 DVD Drive Replacement: 步骤 4 中的图像 1,1
    • If you are only replacing the battery, you can skip this step and the next. Shift the keyboard module away from the display and set it such that the fragile flex cables are not strained.
    • Disconnect the three data cables from the motherboard.
    • To unlock a ZIF connector, use the tip of a spudger or your fingernail to flip up the small, hinged locking flap. Carefully slide the unlocked cable out of the socket.
    询问修复机器人
    添加评论
  5. ASUS D550MA-DS01 DVD Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the fully disconnected keyboard module from the laptop.
    添加评论
  6. ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: 步骤 6 中的图像 1,2 ASUS D550MA-DS01 DVD Drive Replacement, DVD Drive: 步骤 6 中的图像 2,2
    • Remove the single screw that is holding the drive in place using the Phillips #1 Screwdriver.
    询问修复机器人
    添加评论
  7. ASUS D550MA-DS01 DVD Drive Replacement: 步骤 7 中的图像 1,1
    • Slide the drive out to the right of the laptop to disconnect from the motherboard.
    • Lifting the drive straight out without sliding to the right will damage the motherboard.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
团队
IUPUI, Team 1-2, Baechle Fall 2015 IUPUI, Team 1-2, Baechle Fall 2015 的会员
IUPUI-BAECHLE-F15S1G2
3 名成员
创作了8篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 28
总计 855
