跳转到主内容
ASUS Chromebook C424MA-DH48F Speakers Replacement
Anthony Wink
Anthony Wink 另一个贡献者
最后更新于 December 19, 2024
5分钟
非常容易
This is the ASUS Chromebook (Model C424MA-DH48F), here we will be guiding you though replacing the speakers for the ASUS Chromebook.
Reasons to replace the speakers include:
  • Physical damage
  • Poor sound quality
  • No sound at all
  • Sound distortion
你所需要的
工具
查看更多...
  1. ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: 步骤 1 中的图像 1,2 ASUS Chromebook C424MA-DH48F Speakers Replacement, Lower Case: 步骤 1 中的图像 2,2
    • Use a Phillips #0 screwdriver to remove the eleven 6.9 mm screws that secure the lower case.
    • Make sure all the screws on this side get taken out because there could be a label or warranty sticker covering up a screw that might be missed.
    • Insert an opening pick into the gap between the lower case and chassis.
    • Slide the pick around the entire perimeter of the laptop until the lower case fully releases.
    • Remove the lower case.
  2. ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: 步骤 2 中的图像 1,3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: 步骤 2 中的图像 2,3 ASUS Chromebook C424MA-DH48F Speakers Replacement, ASUS Chromebook C424MA-DH48F Battery Disconnection: 步骤 2 中的图像 3,3
    • Use an opening tool to pop up the silver locking bar securing the battery connector.
    • Push the battery connector directly out of its motherboard port.
  3. ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: 步骤 3 中的图像 1,3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: 步骤 3 中的图像 2,3 ASUS Chromebook C424MA-DH48F Speakers Replacement, Speakers: 步骤 3 中的图像 3,3
    • Use an opening tool or your fingernails to gently "walk" the speaker connector directly out of its motherboard socket.
  4. ASUS Chromebook C424MA-DH48F Speakers Replacement: 步骤 4 中的图像 1,1
    • Lift the right speaker up and out of the chassis, with care not to strain the connected cable.
  5. ASUS Chromebook C424MA-DH48F Speakers Replacement: 步骤 5 中的图像 1,1
    • Unseat the speaker wires from the lower side of the battery.
  6. ASUS Chromebook C424MA-DH48F Speakers Replacement: 步骤 6 中的图像 1,1
    • Lift the left speaker up and out of the chassis.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 21
