跳转到主内容
ASUS Chromebook C300MA-DH01 Battery  Replacement
amer khalil
amer khalil3 其他贡献者
最后更新于 April 8, 2024
10 - 15 分钟
中等
This guide will help you replace the battery in your device. Before starting, remember to completely disconnect your device from any power sources and ensure your device is turned off. Always use caution when working with electronic components.
你所需要的
配件
工具
查看更多...
  1. ASUS Chromebook C300MA-DH01 Battery  Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the Chromebook over so the bottom of the device is facing up.
  2. ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 2 中的图像 1,2 ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 2 中的图像 2,2
    • Using the JIS-J0 Screwdriver, remove the following screws from the bottom
    • (5) Five 6mm screws
    • (6) Six 8mm screws
  3. ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 3 中的图像 1,3 ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 3 中的图像 2,3 ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 3 中的图像 3,3
    • Gently wedge the spudger in between the bottom of the device and the keyboard, and carefully pry the cover open. Then, carefully lift up on keyboard.
  4. ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 4 中的图像 1,3 ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 4 中的图像 2,3 ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 4 中的图像 3,3
    • Gently detach connecting cables:
    • Carefully flip up the large black tab.
    • Carefully flip up small white tab.
    • Remove the corresponding black cable.
    • Remove the corresponding white cable.
    • The keyboard will be fully detached at this point.
  5. ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 5 中的图像 1,2 ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 5 中的图像 2,2
    • Using the JIS-J0 Screwdriver, remove the (6) six 6 mm screws from the battery.
  6. ASUS Chromebook C300MA-DH01 Battery  Replacement: 步骤 6 中的图像 1,1
    • Using the plastic opening tool, gently push the connector tab away from the battery to detach the cable.
    • The battery will be fully detached at this point. Carefully lift it out of the device.
结论
amer khalil
于09/26/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S2-G5, Passmore Fall 2017 USF Tampa, Team S2-G5, Passmore Fall 2017 的会员
USFT-PASSMORE-F17S2G5
3 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 237
