跳转到主内容
ASUS Chromebook C200MA DS01 USB Board Replacement
Christopher Lim
Christopher Lim4 其他贡献者
最后更新于 November 25, 2019
10 - 20 分钟
中等
This guide will take you through a step-by-step process for the removal of your Chromebook’s USB board.
你所需要的
工具
  1. ASUS Chromebook C200MA DS01 USB Board Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Before proceeding, power down your Chromebook. Close the display and lay it on a soft surface, top-side down.
    • Remove the five 8.4 mm Phillips #0 screws.
    • Remove the four 4.6 mm Phillips #0 screws.
  2. ASUS Chromebook C200MA DS01 USB Board Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to gently work around the edge of the Chromebook until the back panel starts to lift off.
  3. ASUS Chromebook C200MA DS01 USB Board Replacement: 步骤 3 中的图像 1,1
    • Remove the back panel by lifting it away from the Chromebook.
    • Some clicking will be heard as the panel is removed from the back, this is completely normal.
  4. ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: 步骤 4 中的图像 1,3 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: 步骤 4 中的图像 2,3 ASUS Chromebook C200MA DS01 USB Board Replacement, Battery Connection: 步骤 4 中的图像 3,3
    • To disconnect the battery, pinch the multi-color bundle cable with your thumb and forefinger and pull directly back.
  5. ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: 步骤 5 中的图像 1,3 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: 步骤 5 中的图像 2,3 ASUS Chromebook C200MA DS01 USB Board Replacement, USB Board: 步骤 5 中的图像 3,3
    • Disconnect the USB board ZIF (zero insertion force) connectors which connect the motherboard to the USB board in the upper left.
    • Flip the ZIF retaining flaps up using a plastic opening tool or your fingers.
    • Pull gently on the ribbon cable to disconnect it from the sockets.
  6. ASUS Chromebook C200MA DS01 USB Board Replacement: 步骤 6 中的图像 1,1
    • Remove the three 5.77 mm Phillips screws on the USB board.
    • Remove the two 4.77 mm Phillips screws from the hinge.
  7. ASUS Chromebook C200MA DS01 USB Board Replacement: 步骤 7 中的图像 1,1
    • Use a plastic opening tool to lift the hinge from the Chromebook.
  8. ASUS Chromebook C200MA DS01 USB Board Replacement: 步骤 8 中的图像 1,1
    • Gently lift the USB board from the Chromebook.
结论
Christopher Lim
于04/26/17注册
779 声望
创作了7篇指南
团队
Cal Poly, Team S23-G4, Livingston Spring 2017 Cal Poly, Team S23-G4, Livingston Spring 2017 的会员
CPSU-LIVINGSTON-S17S23G4
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 26
总计 621
