跳转到主内容
加入维修社区 - 创建账户
APEX TM785CH Circuit Board Replacement
你所需要的
    1. APEX TM785CH Circuit Board Replacement, Back Casing: 步骤 1 中的图像 1,2 APEX TM785CH Circuit Board Replacement, Back Casing: 步骤 1 中的图像 2,2
      • Start by bending the tablet back at the top white-colored portion to expose an opening between the back cover and the tablet body.
      • Wedge a plastic opening tool into the opening and push it down to force the back cover off.
      • Move along the top edge of the tablet and repeat the step above.
      • Pull the back cover away from the tablet body to completely remove it.
      询问修复机器人
      添加评论
    1. APEX TM785CH Circuit Board Replacement, Battery: 步骤 2 中的图像 1,2 APEX TM785CH Circuit Board Replacement, Battery: 步骤 2 中的图像 2,2
      • With the back cover removed, you can now see the battery.
      • You will need a soldering/desoldering kit to desolder the 3 battery leads to the circuit board.
      询问修复机器人
      添加评论
    1. APEX TM785CH Circuit Board Replacement, Microphone: 步骤 3 中的图像 1,3 APEX TM785CH Circuit Board Replacement, Microphone: 步骤 3 中的图像 2,3 APEX TM785CH Circuit Board Replacement, Microphone: 步骤 3 中的图像 3,3
      • The microphone is located in the bottom center of the tablet.
      • Remove the black tape holding the wires down.
      • Remove the black tape holding the microphone in place.
      • The microphone is now exposed and can be gently pulled out of the socket.
      询问修复机器人
      添加评论
    2. APEX TM785CH Circuit Board Replacement: 步骤 4 中的图像 1,1
      • You will need a soldering/desoldering kit to desolder the 2 leads where the microphone connects to the circuit board.
      询问修复机器人
      添加评论
    1. APEX TM785CH Circuit Board Replacement, Speakers: 步骤 5 中的图像 1,3 APEX TM785CH Circuit Board Replacement, Speakers: 步骤 5 中的图像 2,3 APEX TM785CH Circuit Board Replacement, Speakers: 步骤 5 中的图像 3,3
      • The speakers are located towards the bottom left and bottom right corners of the tablet.
      • If not already done, remove the black tape holding the wires down.
      • Wedge a spudger underneath the speaker in its socket, near where the wires are connected. You can then pry out the speakers.
      询问修复机器人
      添加评论
    2. APEX TM785CH Circuit Board Replacement: 步骤 6 中的图像 1,2 APEX TM785CH Circuit Board Replacement: 步骤 6 中的图像 2,2
      • You will need a soldering/desoldering kit to desolder the 4 leads where the speakers connect to the circuit board.
      询问修复机器人
      添加评论
    1. APEX TM785CH Circuit Board Replacement, Front Camera: 步骤 7 中的图像 1,2 APEX TM785CH Circuit Board Replacement, Front Camera: 步骤 7 中的图像 2,2
      • To get to the front camera, you will first need to remove the top panel.
      • Unscrew two 2.25 mm Phillips screws with a #00 screwdriver from the top plastic panel to remove it.
      询问修复机器人
      添加评论
    2. APEX TM785CH Circuit Board Replacement: 步骤 8 中的图像 1,1
      • Once unscrewed, use a spudger to pop the panel off by wedging it underneath the panel.
      询问修复机器人
      添加评论
    3. APEX TM785CH Circuit Board Replacement: 步骤 9 中的图像 1,3 APEX TM785CH Circuit Board Replacement: 步骤 9 中的图像 2,3 APEX TM785CH Circuit Board Replacement: 步骤 9 中的图像 3,3
      在这个步骤中使用的工具:
      • First, use plastic coated tweezers to pull up the black release tab.
      • Pull on the black connector with tweezers as close as possible to the white connector base, making sure not to pull on the connector base.
      • It is important to be careful not to damage the black connector tape or the white base.
      • Next, use the tweezers to peel off the tape holding down the connector to the front camera.
      • The front camera can now be removed from its socket.
      询问修复机器人
      添加评论
    1. APEX TM785CH Circuit Board Replacement, Circuit Board: 步骤 10 中的图像 1,3 APEX TM785CH Circuit Board Replacement, Circuit Board: 步骤 10 中的图像 2,3 APEX TM785CH Circuit Board Replacement, Circuit Board: 步骤 10 中的图像 3,3
      在这个步骤中使用的工具:
      • After removing the top panel, battery, speakers, microphone, and front camera from the tablet, you will also need to use the tweezers to remove the connectors indicated in the same method as the previous step.
      询问修复机器人
      添加评论
    2. APEX TM785CH Circuit Board Replacement: 步骤 11 中的图像 1,2 APEX TM785CH Circuit Board Replacement: 步骤 11 中的图像 2,2
      • Using a Phillips screwdriver, remove three 2.25 mm screws from the circuit board.
      • The circuit board can now be removed from the tablet.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
Baylor, Team 4-1, Williams Spring 2015 Baylor, Team 4-1, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G1
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 25
总计 1,063
