跳转到主内容
加入维修社区 - 创建账户
5G mmWave Disconnection
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. 5G mmWave Disconnection, Prepare your Pixel for disassembly: 步骤 1 中的图像 1,3 5G mmWave Disconnection, Prepare your Pixel for disassembly: 步骤 1 中的图像 2,3 5G mmWave Disconnection, Prepare your Pixel for disassembly: 步骤 1 中的图像 3,3
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables from your phone.
    • Completely power off your phone.
    • Press the power and volume up buttons at the same time to bring up the shutdown menu.
  2. 5G mmWave Disconnection, Adhesive information: 步骤 2 中的图像 1,3 5G mmWave Disconnection, Adhesive information: 步骤 2 中的图像 2,3 5G mmWave Disconnection, Adhesive information: 步骤 2 中的图像 3,3
    • The back cover is secured with adhesive around the perimeter and near the cameras. To avoid damaging your phone's internals, note the following:
    • Unless stated otherwise, don't insert your tool more than 3 mm (the width of your opening tool's flat section) around the edges.
    • Don't insert your tool under the edges of the camera bump.
  3. 5G mmWave Disconnection, Insert an opening tool: 步骤 3 中的图像 1,3 5G mmWave Disconnection, Insert an opening tool: 步骤 3 中的图像 2,3 5G mmWave Disconnection, Insert an opening tool: 步骤 3 中的图像 3,3
    • Your opening tool has a flat end and a curved end. During the opening procedure, use the flat end and angle it so the tool's sharp edge points upward.
    • Insert the edge of an opening tool between the back cover and the frame, starting with a sharp corner of the tool to help separate the adhesive.
  4. 5G mmWave Disconnection, Separate the perimeter adhesive: 步骤 4 中的图像 1,3 5G mmWave Disconnection, Separate the perimeter adhesive: 步骤 4 中的图像 2,3 5G mmWave Disconnection, Separate the perimeter adhesive: 步骤 4 中的图像 3,3
    • Slide your opening tool along the bottom edge to separate the adhesive securing the back cover.
  5. 5G mmWave Disconnection: 步骤 5 中的图像 1,3 5G mmWave Disconnection: 步骤 5 中的图像 2,3 5G mmWave Disconnection: 步骤 5 中的图像 3,3
    • Slide your opening tool around the bottom right corner and up the right edge, stopping at the bottom of the camera bump.
    • Remove your opening tool from under the back cover.
  6. 5G mmWave Disconnection: 步骤 6 中的图像 1,3 5G mmWave Disconnection: 步骤 6 中的图像 2,3 5G mmWave Disconnection: 步骤 6 中的图像 3,3
    • Insert your opening tool under the top right corner of the back cover, just above the camera bump.
    • Slide your opening tool along the top edge, stopping at the top left corner just above the camera bump.
  7. 5G mmWave Disconnection: 步骤 7 中的图像 1,3 5G mmWave Disconnection: 步骤 7 中的图像 2,3 5G mmWave Disconnection: 步骤 7 中的图像 3,3
    • Insert your opening tool under the left edge of the back cover, just below the camera bump.
    • Slide your opening tool down the left edge to separate the adhesive.
  8. 5G mmWave Disconnection, Separate the camera bump adhesive: 步骤 8 中的图像 1,3 5G mmWave Disconnection, Separate the camera bump adhesive: 步骤 8 中的图像 2,3 5G mmWave Disconnection, Separate the camera bump adhesive: 步骤 8 中的图像 3,3
    • A strip of adhesive above the camera bump secures the top edge of the back cover.
    • Insert an opening pick under the top left corner of the back cover until the tip is close to the top edge of the camera bump.
    • You can insert the opening pick more than 3 mm along the top edge.
    • Slide the pick to the right, stopping when you reach the right edge of the cameras.
  9. 5G mmWave Disconnection: 步骤 9 中的图像 1,3 5G mmWave Disconnection: 步骤 9 中的图像 2,3 5G mmWave Disconnection: 步骤 9 中的图像 3,3
    • A final strip of adhesive below the camera bump secures the back cover.
    • Insert the flat edge of an opening pick under the back cover, just below the camera bump.
    • Insert a second opening pick in the same spot on the other side.
  10. 5G mmWave Disconnection: 步骤 10 中的图像 1,3 5G mmWave Disconnection: 步骤 10 中的图像 2,3 5G mmWave Disconnection: 步骤 10 中的图像 3,3
    • Pry up simultaneously with both picks and apply constant pressure to separate the final piece of adhesive securing the back cover.
    • Be careful not to bend the back cover. If the adhesive feels stubborn, rotate the cover side-to-side to further loosen the adhesive.
    • If the adhesive isn't separating, you can lightly heat the back cover just below the camera bump with a hair dryer or iOpener to soften the adhesive.
  11. 5G mmWave Disconnection, Remove the back cover: 步骤 11 中的图像 1,2 5G mmWave Disconnection, Remove the back cover: 步骤 11 中的图像 2,2
    • Remove the back cover.
    • During reassembly:
    • Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
    • Follow this guide to apply new adhesive and install your back cover.
  12. 5G mmWave Disconnection, Separate the flash unit: 步骤 12 中的图像 1,2 5G mmWave Disconnection, Separate the flash unit: 步骤 12 中的图像 2,2
    • Use a hair dryer to heat the flash unit to soften the adhesive securing it to the logic board cover.
    • Alternatively, you can use an iOpener or heat gun to warm the flash.
    • Only heat the flash so it's warm to the touch. The battery and surrounding components are susceptible to heat damage.
  13. 5G mmWave Disconnection: 步骤 13 中的图像 1,3 5G mmWave Disconnection: 步骤 13 中的图像 2,3 5G mmWave Disconnection: 步骤 13 中的图像 3,3
    • Slide your pick under the top edge of the flash and lift to separate the adhesive securing it to the cover.
    • Be careful not to slip and tear the flash cable, as it's very fragile.
    • During reassembly, follow this guide to replace the flash adhesives.
  14. 5G mmWave Disconnection, Unclip the logic board cover: 步骤 14 中的图像 1,2 5G mmWave Disconnection, Unclip the logic board cover: 步骤 14 中的图像 2,2
    在这个步骤中使用的工具:
    FixMat
    $36.95
    • While the Pixel 8a uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a Torx Plus 3IP screwdriver to remove the 15 screws securing the logic board cover:
    • Thirteen 4.3 mm‑long screws
    • Two 1.9 mm‑long screws
  15. 5G mmWave Disconnection: 步骤 15 中的图像 1,3 5G mmWave Disconnection: 步骤 15 中的图像 2,3 5G mmWave Disconnection: 步骤 15 中的图像 3,3
    • Be very careful not to damage the spring contacts around your phone's perimeter. Only insert your tool where instructed.
    • Insert an opening pick under the bottom right corner of the logic board cover and pry up to release the clip.
    • Insert the tip of a spudger under the notch near the top right corner of the logic board cover (just below the screw hole) and pry up to release the clip.
  16. 5G mmWave Disconnection: 步骤 16 中的图像 1,3 5G mmWave Disconnection: 步骤 16 中的图像 2,3 5G mmWave Disconnection: 步骤 16 中的图像 3,3
    • Slowly lift the top edge of the logic board cover and thread the flash unit through its cutout.
    • During reassembly, thread the flash through its cutout as you lower the logic board cover into place.
  17. 5G mmWave Disconnection, Remove the wireless charging assembly: 步骤 17 中的图像 1,2 5G mmWave Disconnection, Remove the wireless charging assembly: 步骤 17 中的图像 2,2
    • Remove the logic board cover (which has the wireless charging coil connected to it).
  18. 5G mmWave Disconnection, Disconnect the battery: 步骤 18 中的图像 1,3 5G mmWave Disconnection, Disconnect the battery: 步骤 18 中的图像 2,3 5G mmWave Disconnection, Disconnect the battery: 步骤 18 中的图像 3,3
    • Use a pair of tweezers or your fingers to remove the metal cover on the right edge of your phone.
    • During reassembly, place the upper left corner of the cover under the hook on the logic board before laying it into place.
  19. 5G mmWave Disconnection: 步骤 19 中的图像 1,1
    • This guide was shot with the Verizon model (G8HHN) Google Pixel 8a, which has an extra cable and connector for the 5G mmWave antenna (just to the left of the battery connector). If you have the non-mmWave model, just skip any steps that mention the antenna cable.
  20. 5G mmWave Disconnection: 步骤 20 中的图像 1,3 5G mmWave Disconnection: 步骤 20 中的图像 2,3 5G mmWave Disconnection: 步骤 20 中的图像 3,3
    • Insert the flat end of a spudger under the right edge of the battery press connector and pry straight up to disconnect it.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
    • To prevent damaging the surface mounted components around the battery and 5G mmWave connectors, only pry where instructed.
  21. 5G mmWave Disconnection, Disconnect the 5G mmWave antenna: 步骤 21 中的图像 1,2 5G mmWave Disconnection, Disconnect the 5G mmWave antenna: 步骤 21 中的图像 2,2
    • Insert the point of a spudger under the bottom edge of the 5G mmWave antenna press connector and pry straight up to disconnect it.
结论
Spencer Day
于09/14/22注册
160,136 声望
创作了1,045篇指南
团队
iFixit iFixit 的会员
Staff
123 名成员
创作了23,992篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 81
