跳转到主内容
加入维修社区 - 创建账户
4Sight 9 Screen Replacement
你所需要的
    1. 4Sight 9 Screen Replacement, Cover: 步骤 1 中的图像 1,2 4Sight 9 Screen Replacement, Cover: 步骤 1 中的图像 2,2
      • Place the tablet on its side so that the two screws are facing upward.
      • Remove two 1 mm screws from the left side of the tablet using a Phillips #00 screwdriver.
      询问修复机器人
      添加评论
    2. 4Sight 9 Screen Replacement: 步骤 2 中的图像 1,1
      • Pry the case away from the device slowly by sliding a plastic opening tool along the device.
      • Once loosened, use your hands to separate the case from the device.
      询问修复机器人
      添加评论
    3. 4Sight 9 Screen Replacement: 步骤 3 中的图像 1,2 4Sight 9 Screen Replacement: 步骤 3 中的图像 2,2
      • Hold the positive and negative wires as close as possible to the speaker.
      • Use an opening tool and fingers to simultaneously lift the speaker from the cover.
      询问修复机器人
      添加评论
    1. 4Sight 9 Screen Replacement, Battery: 步骤 4 中的图像 1,1
      • Use soldering gun to remove the positive and negative wires connecting the battery to the circuit board.
      • For a complete guide on how to solder, click here.
      询问修复机器人
      添加评论
    2. 4Sight 9 Screen Replacement: 步骤 5 中的图像 1,2 4Sight 9 Screen Replacement: 步骤 5 中的图像 2,2
      • Insert plastic prying tool under upper-hand corner of battery and slide back and forth.
      • Once loosened, insert plastic prying tool under lower-hand corner and repeat sliding action.
      • Repeat previous actions until battery comes loose from device.
      询问修复机器人
      添加评论
    1. 4Sight 9 Screen Replacement, Screen: 步骤 6 中的图像 1,2 4Sight 9 Screen Replacement, Screen: 步骤 6 中的图像 2,2
      • Grip the ribbon located at the far end of the circuit board with a plastic spudger tool.
      • Put pressure on the connector until the clasp comes undone.
      • Gently pull up on electrical ribbon until it disconnects from circuit board.
      询问修复机器人
      添加评论
    2. 4Sight 9 Screen Replacement: 步骤 7 中的图像 1,2 4Sight 9 Screen Replacement: 步骤 7 中的图像 2,2
      • Remove the second electrical ribbon from the motherboard using the same technique used to remove first ribbon.
      询问修复机器人
      添加评论
    3. 4Sight 9 Screen Replacement: 步骤 8 中的图像 1,1
      • Using #00 Phillips Screwdriver, remove the four 1mm screws holding the circuit board to the device.
      询问修复机器人
      添加评论
    4. 4Sight 9 Screen Replacement: 步骤 9 中的图像 1,2 4Sight 9 Screen Replacement: 步骤 9 中的图像 2,2
      • With fingers, grip the green Wi-Fi connector.
      • Gently pull up on connector to remove tape holding the connector in place.
      询问修复机器人
      添加评论
    5. 4Sight 9 Screen Replacement: 步骤 10 中的图像 1,2 4Sight 9 Screen Replacement: 步骤 10 中的图像 2,2
      • With the motherboard facing you, look to the bottom left corner, pull on the camera to completely free the motherboard.
      询问修复机器人
      添加评论
    6. 4Sight 9 Screen Replacement: 步骤 11 中的图像 1,1
      • Using your fingers, gently lift the motherboard and battery.
      询问修复机器人
      添加评论
    7. 4Sight 9 Screen Replacement: 步骤 12 中的图像 1,3 4Sight 9 Screen Replacement: 步骤 12 中的图像 2,3 4Sight 9 Screen Replacement: 步骤 12 中的图像 3,3
      • Insert plastic prying tool under screen and exert pressure, pulling upward.
      • Repeat this step around each corner of the screen until it pops off.
      • Ensure screen is free from all black tabs holding it in place.
      询问修复机器人
      添加评论
    8. 4Sight 9 Screen Replacement: 步骤 13 中的图像 1,1
      • Place heating pad on glass frame in order to loosen adhesive for 3 to 5 minutes
      • Remove plastic film from glass frame
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
7等其他人完成本指南。
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 37
总计 3,440
