跳转到主内容
2015 Jeep Patriot Tail/ Brake Light Replacement
Yadira Vera
Yadira Vera5 其他贡献者
最后更新于 June 8, 2023
20 - 40 分钟
中等
需要更好的图片
缺少的步骤
To ensure the safety of drivers, it is important to have functioning brake lights. If the brake lights on your 2015 Jeep Patriot aren't illuminating and need to be replaced, use this guide to replace the lightbulb.
The purpose of a tail/ brake light is to make your car visible during nighttime and heavy weather conditions and to communicate to the driver behind you that you are slowing down or stopping. A broken tail/ brake light is dangerous to yourself and the drivers around you. You could also get pulled over and receive a citation if your tail light is out.
Before beginning the repair, park in a safe location, turn the car off and put the emergency brake on.
你所需要的
配件
工具
查看更多...
  1. 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: 步骤 1 中的图像 1,2 2015 Jeep Patriot Tail/ Brake Light Replacement, Jeep Patriot Tail/ Brake Light Replacement: 步骤 1 中的图像 2,2
    • Open the trunk and locate the fender clips.
    • These are located near the tail lights.
  2. 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 2 中的图像 1,3 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 2 中的图像 2,3 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 2 中的图像 3,3
    • Use the 3/16 inch flathead screwdriver to remove the top fender clip holding the tail light on.
  3. 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 3 中的图像 1,1
    • Remove the lower fender clip.
    • This will release the tail light so be careful.
  4. 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 4 中的图像 1,2 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 4 中的图像 2,2
    • Remove the tail light to expose the light bulb.
  5. 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 5 中的图像 1,2 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 5 中的图像 2,2
    • Twist the light bulb to remove it from the holder.
    • Replace the old bulb with the new one. make sure to twist the new bulb to secure it.
    • Do not touch the new light bulb with your bare hands as the oil from your fingers will cause it to degrade faster and possibly shatter.
  6. 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 6 中的图像 1,2 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 6 中的图像 2,2
    • Align the two pegs on the tail light housing with the matching holes on the car.
  7. 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 7 中的图像 1,2 2015 Jeep Patriot Tail/ Brake Light Replacement: 步骤 7 中的图像 2,2
    • Reinsert the top and bottom fender clips.
结论
Yadira Vera
于10/26/22注册
145 声望
撰写一个指南
团队
CSU Los Angeles, Team 1-7, Briggs Fall 2022 CSU Los Angeles, Team 1-7, Briggs Fall 2022 的会员
CSULA-BRIGGS-F22S1G7
1 名成员
创作了1篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 21
过去 30 天: 133
总计 3,657
