本指南有最近更改,您可查看未经巡查的最新版本。
简介
The chain transfers the power of your pedaling feet to the rear wheel. When your chain is damaged or not working properly it can make your ride extremely difficult or you may not be able to ride at all. Your chain could be stretched or bent. This guide will walk you through the steps of properly removing your chain and installing a new one.
你所需要的
Identify the master link on your bicycle chain, push the ends of the master link together and the link will disconnect, it may require a lot of force. If you have done this, skip step 2. If you cannot find one, your chain may not have one.
If you do not have a master link on your chain, use the chain breaker to separate any two links of the chain.
After such extensive work on the rear tire and chain, it is always a good idea to realign your rear derailleur.
