跳转到主内容
How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables
你所需要的
  1. How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables, How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 步骤 1 中的图像 1,2 How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables, How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 步骤 1 中的图像 2,2
    • First, we need to set the high and low bounds on position that the derailleur can travel to.
    • Shift the rear derailleur so it is in the 8th gear position.
    • Using the phillips head screw driver, adjust the screw labeled with an H so that the derailleur lines up vertically with the 8th gear (the smallest one).
  2. How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 步骤 2 中的图像 1,3 How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 步骤 2 中的图像 2,3 How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 步骤 2 中的图像 3,3
    • Set the low bound by shifting the rear derailleur to its 1st gear position. Adjust the screw labeled with a L, so the derailleur lines up vertically with the 1st gear.
    • If you are unable to get the low bound over far enough by adjusting the screw, try tightening the cable using the adjustment knob found on the shifter itself.
  3. How to adjust and maintain 2006 Iron Horse Warrior Rear Derailleur Cables: 步骤 3 中的图像 1,1
    • The last thing you need to adjust is the distance the derailleur moves between gears.
    • Shift the derailleur into either the 4th or 5th gear, and adjust the hex screw found on the back of the derailleur to make sure the derailleur lines up vertically with the gear the bike is in.
终点
另外一个人完成了本指南。
Scott Kaufman
于04/20/15注册
619 声望
创作了3篇指南
团队
Cal Poly, Team 15-2, Amido Spring 2015 Cal Poly, Team 15-2, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 1,660
