当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Identify the master link on your bicycle chain, push the ends of the master link together and the link will disconnect, it may require a lot of force. If you have done this, skip step 2. If you cannot find one, your chain may not have one.
If you do not have a master link on your chain, use the chain breaker to separate any two links of the chain.
这个步骤还没有翻译 帮忙翻译一下
Weave the chain thru the rear derailleur, make sure to guide the chain thru the rear chain guard.
It can be cramped, pulling down the derailleur can often be helpful.
The last image highlights the chains path thru the sprockets.
Holding the end of the chain in place, proceed to step 5.
这个步骤还没有翻译 帮忙翻译一下
After such extensive work on the rear tire and chain, it is always a good idea to realign your rear derailleur.
