当前版本的文档还未经巡查,您可以查看最新的已查核版本。
简介
子板包含USB-C接口,麦克风和其他硬件。这份指南能教你如何在不损坏其他组件的情况下移除子板。在开始前请确定你拥有下列用来有效完成更换所需要的所有工具。我们还建议你在使用吸盘、撬棍和镊子时要格外小心。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
Remove the motherboard.
Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
这个步骤还没有翻译 帮忙翻译一下
Use a hairdryer or heat gun, or prepare an iOpener and apply it to the bottom of the back of the phone for about a minute, in order to soften the adhesive securing the charging assembly.
倒叙操作这份指南来重装你的设备。
倒叙操作这份指南来重装你的设备。
32等其他人完成本指南。
由衷感谢以下译者:
0%
roanoke正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
12条评论
Why do I need the Tesa 61395 Tape for this repair? I don’t see it used anywhere in the guide.
Jay Huxley - 回复
Hey Jay,
The Tesa tape is needed only necessary if you do not use the custom-cut back display panel adhesive.
Should I apply some kind of glue around the port?
Is there any possibility to keep it waterproof?
Hi Erik,
Once you have opened the phone, there is no reliable DIY way to make it water resistant.
