简介
使用本指南更换罗技 G PRO 无线鼠标的电池。
更换 G PRO 鼠标的电池时需要取下鼠标脚垫。 如果你打算重复使用鼠标脚垫,请加热脚垫并尽可能的不要弯折脚垫。 如果脚垫有弯折或是撕破则无法重复使用。
为了安全考虑,请在拆卸鼠标前将确保鼠标电池的电量在25% 以下。 这样可降低在维修过程中电池意外损坏而发生的危险。如果你的电池鼓包了, 请参考此处.
你所需要的
请对比新零件和原始的零件--你可能需要在组装前转移剩余的零件或从新零件上移除背胶。
若要重新组装您的设备,请按照相反的顺序执行这些说明。
请将您的电子垃圾送到[e-waste |R2或e- steward认证的回收商|new_window=true]。
修理遇到困难? 试试 故障排除, 或者访问我们的罗技 G PRO 论坛 寻求帮助.
15等其他人完成本指南。
由衷感谢以下译者:
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
6指南评论
Worked entirely fine for me. Since I bought replacement sliders/feet as well, I just skipped the warming up steps. The glue still separated very easily and overall took me like 10 seconds to remove all feet
Regarding the battery/flex-cable step, I personally removed the flex cable first as it’s much more fragile and less replaceable than the battery cable
I also removed the logic board to clean the area below, it’s pretty straight-forward. The only thing one has to remember is where the on/off switch colors go again during re-assembly. Answer: the blue side is at the bottom (when the PRO Wireless label is readable and NOT upside-down), you can find a photo in step 10
The symptoms I had before the repair were a bit weird, which is why I initially wasn’t sure if it’s the battery or not. Basically, my mouse wouldn’t charge a lot, but also wouldn’t work for a long time while connected via cable. Both of these appear to be fixed now (I’ll try to remember to update this comment if it turns out to be broken)
For a replacement battery, I managed to find an original battery on eBay that was disassembled from a returned mouse. That way I could be sure I’m not going to receive some potentially dangerous knock-off version, which I didn’t want to risk.
The locking flap on the input cable ZIF connector just broke in half when I tried this teardown. Would you happen to know where I can buy a replacement, if there's any?
Anybody know of a good battery to use as a replacement? I searched a while back and couldn't find a source I was confident in.
Jason Tran - 回复
Note to all - I'm assuming the battery must run in series with the power/data cable. So if you are having battery issues (battery not charging) and waiting for the replacement to arrive, you can remove battery re-assemble and use the mouse plugged in/switched off as if it were wired in the interim!
