简介
在大约500次的充电循环后,iPhone的电池容量将会下降至80%左右,这一过程对于大多数的用户来说大约为18 - 24个月。在这之后,你的iPhone也许需要更频繁的充电,且iOS可能会提示你手机的性能受到了影响(换句话说,你的手机运行变慢了)。使用本指南来更换新的电池,使你的手机像刚买时一样流畅。
如果你的电池产生了鼓包现象,请参阅此指南: 请谨慎操作.
本指南将会指导你完整的拆下显示屏并移除扬声器和Taptic Engine 来更好地处理电池表面的粘合物。
为了在完成本指南所述步骤后让你的手机达到最佳性能,需要校准你的新电池:完全充电至100%,并保持充电至少两个小时。然后使用至电量耗尽。最后,再完全充电至100%。
你所需要的
视频概述
从尖端测量 3 毫米,并用永久性记号笔标记三角撬片。
Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
what fix kit?
My fix kit didn't include an opening pick either
My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
将蓝色手柄向后拉,解锁反向钳的手臂。
将手臂滑过 iPhone 的左边缘或右边缘。
将吸盘靠近 iPhone 的底部边缘——一个在前面,一个在后面。
将吸盘一起挤压,以向所需区域施加吸力。
加热 iOpener 并将其穿过反向钳的手臂。
把 iOpener 折叠起来,放在 iPhone 的底部边缘。
等待一分钟,让粘合剂有机会释放,形成一个开口缝隙。
将打开工具插入开口缝隙,位于屏幕和塑料边框之下,而不是屏幕本身。
跳过接下来的三个步骤。
使用吹风机或加热枪,或者准备一个iOpener,把它涂在iPhone的下边缘大约一分钟,以便软化下面的粘合剂。
besteht da die Gefahr das sich das Displayglas vom lcd löst?
Besteht da die Gefahr das sich der Kleber vom Displayglas löst?
保持相同的力量匀速向上拉动吸盘,使前面板与后壳之间露出微小的缝隙。
将撬片插入缝隙,位于屏幕和塑料边框之下,而不是屏幕本身。
在iPhone的底部沿边缘插入您的拆机翘片,然后向右滑动,继续分离粘合胶。
卸下固定顯示器連接器支架的三個Y000螺釘:
兩個1.5毫米螺釘
一個1.1毫米螺釘
I am replacing the screen for the 2nd time - the first repair was done by someone else, and the first 2 screws are 1.5mm and the last screw is 1.1mm… If I put the screw back in am I risking Long Screw Damage?
Thanks for all your comments! I'll amend this step.
Arthur Shi - 回复
Hi, I just changed the screen on my XS Max and for this bracket I used 2 x 1.1 mm and 1 x 1.5 mm.
Starting from left to right:
- left 1.1 mm (I tried with 1.5 mm like in the above picture but I felt that it didn't wanted to go deeper so I didn't forced and I tried it in the middle and it fit perfectly)
- middle 1.5 mm
- right 1.1 mm
For the two brackets I had 7 screws, I aligned them on the desk by length and I had 2 x 1.5 mm, 4 x 1.1 mm and 1 x 3.7 mm.
Good luck and I hope it will help someone!
卸下固定 Taptic Engine 和主扬声器下方两个支架的五颗 1.4 mm Y000 螺丝:
移除扬声器。
Welche Dichtung soll hier verwendet werden?
如果胶带脱落,而电池仍然粘在后盖上。此时你需要准备一台 iOpener 或热风机,对iPhone 的后盖直接进行加热。
将 iPhone 翻转过来,在电池上方穿过一根结实的绳子(比如一段牙线或是吉他弦)。
以锯切运动将绳子从一侧拉到另一侧以分离粘合剂。这可能需要一些时间,因为粘合剂变形缓慢,但一定要保持耐心,它最终一定会被分开。请勿变形或损坏电池。
将绳子从电池的顶部或底部边缘开始,向iPhone中间拉。但请勿将电池线穿过电池的中间三分之一,否则可能会损坏排线或位于下方的无线充电线圈。
将你新更换的部件与原先的部件对比—— 你可能需要在安装开始前转移剩余的部件或去除新部件上的包装。
想要重新组装设备,仅需按照上述步骤相反的顺序执行
将你更换下来的废旧部件妥善处理:R2 or e-Stewards 认证的回收商。
在维修过程中遇到问题?访问我们的论坛 以获取帮助。
72等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
8条评论
Does anyone have an answer to my issue I’m currently facing? Bought a refurbished iPhone XS Max online and looks like the seller has replaced the battery, however the phone is experiencing technical difficulties as it keeps switching off and restarting every 1 minute or so. Could this be because they didn’t use a genuine apple battery as a replacement or they just didn’t fit the battery correctly when replacing it? I really appreciate if anyone could help, would save me a tonne of money that apple will probably charge me if I go to them for help.
PIXIE DUST - 回复
They probably used a “amazon” battery the best way would be to replace it your self.
Ein Hinweis darauf, wie man das Batteriemanagement-Board vom alten Akku auf den neuen Akku überträgt wäre als Add-on sicher hilfreich. Der Aufwand ist überschaubar (Werkzeug wird benötigt), und dann erscheint auch die Meldung mit der Batterienachricht nicht mehr.
