简介
参阅本指南来替换你的 iPhone 7 Plus 内的 Lightning 接口组件,可以解决充电或数据连接等问题。
你所需要的
移除 Lightning 接口组件。
使用塑料工具移除后壳上所有残留的粘胶。
你可以使用蘸取(90%或以上浓度)的酒精的无绒布清洁表面的残留物。注意仅朝一个方向擦拭,不要来回擦。
确保将 Lightning 接口组件排线上的两个小孔对准手机后壳上的两个小白点。如果没对准的话,会导致排线偏移,并且排线上的插头无法连接到主板上的插座上。
将你新更换的零件与原始零件进行比较——你可能需要在安装前转移剩余的组件或去除新零件上的背胶。
按本指南的相反步骤操作来重新组装你的设备。
将你的电子垃圾带到 R2 or e-Stewards 认证的回收商。
193等其他人完成本指南。
由衷感谢以下译者:
90%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
41条评论
NOTE TO ALL: When you put the port back in, LINE UP THE HOLES ON THE FRAME. If you don’t line up the holes perfectly on the cable (even if it’s off by a millimeter), the cable will NOT extend and plug into the logic board. It has to be perfect. You’re welcome :)
I have this issue but cant seem to get it to set properly? any ideas the po seems like it's in fine but wont connect to logic board
I feel like this is the most important piece of information on this entire guide. I drove myself mad disassembling and reassembling multiple iPhone 7/8 Plus devices with this exact issue.
Conrad -
So i did this and now my home button does not work. Any suggestions?
So far as I can tell, the only part of this procedure that affects the home button is when it’s disconnected from the board in step 14. I’d probably double-check those connectors to make sure they’re seated properly for a start. Check the sockets for dust/debris or pin damage. Inspect the cables for damage. While you’re troubleshooting, remember to always disconnect the battery first and reconnect it last. Good luck!
