简介
使用本指南可升级或更换 MacBook Air 13" Early 2017 中的固态硬盘。
在执行此维修之前,如果可能的话,请备份现有的固态硬盘。然后,熟悉在线备份或创建可启动的外部驱动器,这样你就可以将 macOS 安装到新硬盘上,并将数据迁移到新的固态硬盘上。
最后,我们强烈建议你在更换 MacBook Air 上原有的固态硬盘之前,先安装 macOS 10.13 High Sierra(或更高版本的 macOS)。大多数新固态硬盘都需要更新存储驱动程序,而在 High Sierra 之前的 macOS 版本中找不到这些驱动程序。
你所需要的
在这个步骤中使用的工具:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
使用P5 Pentalobe 螺丝刀将底部的十颗螺丝移除,有下面两种规格:
两个9mm 梅花形螺丝
八个2.6mm梅花形螺丝
要重新组装您的设备,请反向遵循这些说明,并使用我们的粘合剂指南重新装上显示屏玻璃。
将您的电子垃圾送到R2 或 e-Stewards 认证的回收商。
48等其他人完成本指南。
由衷感谢以下译者:
100%
Yanqi Wang正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
22指南评论
Thanks! My wife’s MacBook Air is now rocking a 480GB drive (upgraded from 128GB).
Very easy to follow step…great job. Took less then 10 minutes. Upgraded Macbook Air (2017) from original 120GB to 480GB SSD. I used TimeMachine backup to perform the restore, which went flawless and was completed in under 3 hours.
Key is to press Option + Command + R to bring up “Internet Recovery”. If you press Command + R, the new drive will not be recognized and won’t be shown.
The introduction states, “This MacBook Air uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.” However, both the parts list and step 5 (the last step shown on my screen…am I missing later steps?) do not mention this adapter. Is the adapter truly needed?
Yes, if you search the major online retailer that is also a river in South America, you will find adapters for standard m.2 drives (samsung, crucial, etc.) If you do not want to use an adapter, you can purchase a drop in replacement from OWC, however they are more expensive.
When I use an M.2 drive with adapter, I can use any ssd? or they need to be compatible in a logic way? (not hardware but software compatible)
