简介
使用本指南在您的三星手机或平板电脑上重置电池循环次数。 每次更换三星设备的电池时,都应进行重置。
本程序目前适用于 S20 系列(不支持 S20 FE)、(不支持 Note20 和 Note20 Ultra)、S21 系列(包括 S21 FE)、S22 系列、S23 系列(包括 S23 FE)、S24 系列、Z Fold5、Z Flip5、(Z Fold1, Fold2, Fold3, Fold4, Fold6, 及 Z Flip1, Flip2, Flip3, Flip4, Flip6 均不支持)、A54、Tab S7+(不支持 Tab S7 和 Tab S7 FE)、(不支持 Tab S8 系列)和 Tab S9 系列(包括 Tab S9 FE 和 Tab S9 FE+)。本指南将随着三星增加更多兼容性而更新。 有关详细信息,请参阅 三星 维修指南 。
注:本指南使用的设备是三星 Galaxy Tab S7+,但所有三星设备的步骤都是相同的。
注:需要 Samsung 帐户。
选择屏幕右侧的应用程序。
选择“安装”以确认应用程序的安装。
跳过接下来的两个步骤。
选择 Galaxy Cal 应用程序
Bei meinem S20 FE 5G kommt beim Starten der App die Meldung:
This Model is NOT Supported
Gibt es sonst noch eine Möglichkeit?
DasMarki _ - 回复
Says galaxy s20fe is not supported?
I want FE support as I have an S20 FE 5G.
On my S9 it installs but the window of the app closes instantly after opening.
Rbn Vn Drn - 回复
11等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
33条评论
Dead link to Samsung Self-Repair document.
Thanks for catching that! I fixed the link in the introduction.
I installed the galaxy cal app on an S20 and when opening the app I get a message to try again after getting new version
I have the same. Do you know how to fix this now?
simply change your phone date between 2021 and 2022.
When opening the app it says model not supported .I'm using a galaxy-s20-fe
me too. cant find in store either
Set your phone date between 2021 to 2022
蓝泽希 -
Hello again, when the prompt show there yoy should get new version just simple change the date back in past
Good catch! I changed it to Sept 30 2022 and then the app started.
I installed the galaxy cal app on an S20, Android 13 too and when opening the app I get a message to try again after getting new version.
Tried on 3 devices, same result :(
Resetting the date was the right clue, thx :)
I have the same question that the application shows it needs updating before opening it. Version is SM-G9860, Oneui5.1
James Zhao - 回复
I hope to see an increase in compatibility for the Note20 series.
Can you please add support for the fe series devices because I have an s20 fe 5g and need to replace my battery.
Would be nice to have, but not possible. As the Prolog says:
Diese Vorgehensweise funktioniert nur auf dem S20, S21, S22 und TabS7+ Modellen. Sie gilt nicht für Fan Edition (FE) Modelle. Diese Anleitung wird aktualisiert, sobald Samsung weitere Modelle hinzufügt.
"... Not suitable for the Fan Edition (FE) Modells. ..."
BenZ78 -
Can you please add s23 series support for in the future as I have an S23 Ultra. Also for those of you who have the "try again after getting new version" error just change your device's date to Oct. 1st 2022 or earlier.
Hallo,
danke für Euren Tipp.
Ich habe diese Version für mein S22 plus heruntergeladen und installiert. Nach dem Start der App, wollte die App aktualisiert werden. Habe ich gemacht und jetzt will die App eine Seriennummer meines Akkus. Version 2.0.10
Kann ich das irgend wie auslesen lassen?
Mfg
Is there a compatible version for the Samsung S10E?
Did you try the latest version 2.0.12 from the Samsungparts link in step 1 in the unverified but updated version of this guide?
Hi all. Why doesn't the program support Samsung 20FE? Is there a way to reset the charge counter?
Hallo
Leider sagt die app das ei e Verwendung auf dem s21fe nicht möglich ist. Gibt es dafür Lösungsansätze?
benbaschke - 回复
Use the latest version 2.0.12 in the unverified version of this guide. I tested it on devices in Samsung's Remote Test Lab and it should work for your S21FE.
Verwenden Sie die neueste Version 2.0.12 in der nicht verifizierten Version dieses Handbuchs. Ich habe es auf Geräten im Remote Test Lab von Samsung getestet und es sollte für Ihr S21FE funktionieren.
Change phone date to 2021
when i start the calibration, the apps shows that need a serial or qr of the battery, how can i get it?
at the back of the battery there is QR code or at the front I am not so sure which one to use. there is also serial number beside the QR code at the back
Hallo, can i use it for my galaxy S21 5G ?
Yes I've tested it on that model in Samsung's Remote Test Lab on their developer website and it works.
The Self Repair Assistant is now working on one ui 6.1
Jayson Chua - 回复
Je trouve mas l'application
Oussama Reddaf - 回复
Make sure to set your phone date to year 2022 before using this app version. If you don't, it will not work and ask you to download the latest version.
Do not use the latest version of this app as it will ask for Samsung-made battery serial number (really Samsung. copying Apple for this is anti-consumer).
Peter Chang - 回复
