跳转到主内容
任天堂 New 2DS XL C摇杆更换
你所需要的
  1. 任天堂 New 2DS XL C摇杆更换, 拆卸后盖准备工作: 步骤 1 中的图像 1,1
    • 在开始拆卸之前,要先取出:
    • 触控笔
    • 游戏卡
    • SD 卡
    This is a great repair instructional, but I would advise also looking at the below video link. (I used both.) Sometimes watching 2 repair guides can help when you think you think you’re stuck. For example, I had a really hard time getting the hinge off!
    https://www.youtube.com/watch?v=Zuu_T2ls...
    (HINT: Works best if you rotate it 180 degrees, so that you are repairing it from the same perspective as the technician)
    skat1140 - 回复
  2. 任天堂 New 2DS XL C摇杆更换, 移除后盖: 步骤 2 中的图像 1,1
    • 拧开位于底板四个角的四颗6毫米三点式螺丝。
    The Y0 was too big; I ended up using a Y00 and that worked fine
    Christopher Gilmer-Hill - 回复
    Would not recommend using a Y000 like I tried to do
    Daniela Magaña-Ochoa - 回复
    gotta use Japanese Industry Standard YOO (blunt end)- I did not, and accidentally stripped two of the screws… still trying to figure out how to remove them -_-;
    Yanko Artidiello - 回复
    Yeah I can confirm, the y0 does not work.
    Arc Turus - 回复
    I'm using the Y-0.6 and seems to only unscrew 2 of the screws on the right side of the handheld, the other 2 aren't moving
    Xx_Definity_J0rd4n_xX - 回复
    screws are too tight
    Albert Einstien - 回复
  3. 任天堂 New 2DS XL C摇杆更换, 机身分离: 步骤 3 中的图像 1,2 任天堂 New 2DS XL C摇杆更换, 机身分离: 步骤 3 中的图像 2,2
    • 将底板与前壳分离时要小心,以免弄断与主板相连的三条电缆(两侧各两条,后面一条)。
    • 用撬棒轻轻撬动后面板,将其与前壳分离。
    • 外壳的铰链上有很多夹子,因此建议在完成最后一个短边之前先沿着一个短边和两个长边进行操作。
    You need to be super careful separating the top from the bottom at the rear end. I got stuck there, applied a lil more force and ripped the right shoulder button straight off the pcb!
    Dominik Leicht - 回复
    The front headphone Jack got stuck in the bottom case and snapped when opening, didn’t notice until after replacing the battery (which is a nightmare btw) I used some floss underneath the battery to give you better leverage since the side plastic is so thin and fragile. I cannot get the headphone Jack back into position now and will have to take it to a shop for (I’m sure much more expensive) repairs. Honestly DO NOT try repair this thing, just pay someone else to repair these. Compared to the OG 2011 3DS these are a nightmare to work with. Nintendo really went out of their way to make this impossible to repair, I had an extra set of pretty capable hands too.
    radioactiverhino 04 - 回复
    I also ripped off the headphone jack when taking the case apart. I never pulled hard. You need to be careful to give the headphone jack clearance before applying any force.
    Mikaela Orbon - 回复
  4. 任天堂 New 2DS XL C摇杆更换: 步骤 4 中的图像 1,3 任天堂 New 2DS XL C摇杆更换: 步骤 4 中的图像 2,3 任天堂 New 2DS XL C摇杆更换: 步骤 4 中的图像 3,3
    • 使用镊子,轻轻向上拉动连接两侧后置按钮和主板的两根电缆,断开它们。
    I unfortunately took off the base of one when trying to pull apart. Is there a fix or will it not be broken?
    Phoenix Typhoon - 回复
    Did you manage to fix this at all?
    Owen McKay -
    When you are putting these cables back, make sure to check the orientation of the cable. You have to match the cable head to the entry point, so you may have to turn the cable around. I spent a bit too much time trying to connect the cables just because I didn't realize that I had to turn the cable around.
    Hongda Wang - 回复
    Aren't these the speaker cables? I haven't taken any 2DS's apart in a while, but I'm pretty sure these cables connect to the speakers
    darth mango - 回复
  5. 任天堂 New 2DS XL C摇杆更换, 移除电池: 步骤 5 中的图像 1,2 任天堂 New 2DS XL C摇杆更换, 移除电池: 步骤 5 中的图像 2,2
    • 用撬棒把电池抬出来。
    • 请注意,有一个粘性的垫子将电池固定在其托盘上。可能需要使用多种工具来轻轻地将电池从托盘和主板上撬开。
    Some might see this as an optional step. But you probably do NOT want to skip this. I did, and now I have malfunctions on the Nintendo (touch screen functionality not working, possibly as a result of shorts from skipping this step.)
    skat1140 - 回复
    Personally, I skipped this step and everything still works fine. I wasn't able to take the battery out because the adhesive was too strong.
    Hongda Wang - 回复
    Small square of adhesive. Pull up slowly and it’ll release after 10-20 seconds
    Jacob Cocanig - 回复
    Any advise for dealing with CTR-003 spicy pillow? So far in this transplant operation, both my devices batteries are okay... but... I dunno, if I were to run into a spicy pillow in the future, what would be the least awful way to pull it out?
    Not sorry, when I see these repair jobs that involve the company gluing the battery into the device (or even soddering in that soon to be spicy pillow) this is just something I'm wondering about
    Katrina Payne - 回复
    I haven't taken my 2ds apart yet, depending on how devices are built it might work to slide a solid thread (eg fishing rope, or floss but that might rip) under it, and do a sewing motion.
    Franziska (Natsu) -
  6. 任天堂 New 2DS XL C摇杆更换, 相机组件: 步骤 6 中的图像 1,3 任天堂 New 2DS XL C摇杆更换, 相机组件: 步骤 6 中的图像 2,3 任天堂 New 2DS XL C摇杆更换, 相机组件: 步骤 6 中的图像 3,3
    • 为了更容易接触到这条带状电缆,翻转设备,使后壳朝上。轻轻地将后壳向前滑动,露出连接到主板的带状电缆。
    • 用撬棒撬起固定带状电缆的ZIF连接器。
    • 将色带拉向底部外壳并从连接器中取出。
  7. 任天堂 New 2DS XL C摇杆更换, C 摇杆: 步骤 7 中的图像 1,2 任天堂 New 2DS XL C摇杆更换, C 摇杆: 步骤 7 中的图像 2,2
    • 用PH000螺丝刀卸下两个7.5毫米的小螺丝。
    • 轻轻地翻开圆垫。请注意,圆盘垫被压在箱子前面的C摇杆的背面。如果要把它从圆垫的背面撬出来,就必须轻轻地撬。
    • 请注意,在C摇杆模块和摇杆棒之间有一个黑色塑料盘。在重新组装过程中,将设备竖立起来,将塑料盘挂在C摇杆模块上,并从正面握住摇杆棒,将它们重新压在一起。
  8. 任天堂 New 2DS XL C摇杆更换: 步骤 8 中的图像 1,3 任天堂 New 2DS XL C摇杆更换: 步骤 8 中的图像 2,3 任天堂 New 2DS XL C摇杆更换: 步骤 8 中的图像 3,3
    • 用撬棒将ZIF连接器抬起来(铰链位于最靠近电缆连接处的一侧)。
    • 将C摇杆从连接器上拉开,将其取出。
    You'll need to push the circle pad through groove out the front face plate.
    Adedamola Odutola - 回复
    Hello I have followed the steps to this tutorial but is there another where it shows you how to put it back in it original state? Like showing us how to put it back to normal.
    Carter Lewis - 回复
结论
要重新组装您的设备,请按相反顺序按照这些说明进行操作。
6等其他人完成本指南。
由衷感谢以下译者:
en zh
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
Tim Newman
于09/25/17注册
1,814 声望
创作了4篇指南
团队
Cal Poly, Team S18-G6, Forte Fall 2017 Cal Poly, Team S18-G6, Forte Fall 2017 的会员
CPSU-FORTE-F17S18G6
5 名成员
创作了20篇指南
5条评论
I can’t seem to find a New 2ds XL circle pad replacement online, does anyone know if a regular 2ds circle pad works? (Or perhaps a 3ds one?)
Dvdcd - 回复
Future Myself, the 3ds circle pad kinda works. The major change here is the screw holes, they were moved in on the 2ds xl, so if you do some sanding and finagling it will work, but it’s not elegant at all.
Dvdcd -
Excellent guide, although I believe the 2ds XL requires a Y00 and not a Y0
Gabrielle Watson - 回复
Can confirm the other comment, the outside screws are Y00.
If you're not confident removing the top ribbon you can just flip over the back carefully and change the circle pad that way.
You also don't have to remove the battery if it's too hard to remove, my one was stuck down like crazy so I just left it and everything is fine.
I just used a generic 2DS/3DS XL replacement circle pad and it works fine.
Daan - 回复
Does anyone know why removing the battery is necessary? Seems unrelated to the circlepad replacement.
Blank - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 87
过去 30 天: 390
总计 16,124
