跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
三星 Galaxy S9 屏幕更换
你所需要的
  1. 三星 Galaxy S9 屏幕更换, 后盖玻璃移除: 步骤 1 中的图像 1,1
    • 在开始之前,请关闭手机。
    • 将加热的 iOpener 应用到手机的长边,以松开后玻璃下方的粘合剂。使用 iOpener加热至少两分钟。
    • 在拆卸过程中,你可能需要多次重新加热并重新施加 iOpener,以使粘合剂足够温暖以便切割。
    • 按照 iOpener 说明操作以避免过热。三星Galaxy S9的粘合剂非常强大。如果你无法使用iOpener打开设备,也可以使用吹风机,热风枪或热板。小心不要让手机过热 —— AMOLED显示屏和内置电池都容易受到热损坏。
    Nightmare. Impossible to get the back off so far. Being trying using the iOpener with hair dryer for last 1hr. No chance.
    Chris Bunney - 回复
    You’re right Chris. I’ve tried on 3 separate occasions now and haven’t been able to budge that back. All that has happened is the pick has taken a piece out of the glass back leaving a rough edge now.
    grahamcatto - 回复
    it was not easy but doable.
    Clinton Stark - 回复
    It’s difficult, but the trick I did to get it was to wrap the hot iOpener around a bottom corner, apply the suction cup, then I covered the opener and phone with a paper plate, better insulating the area. Then I set my blow dryer to high heat and low velocity and heated the area under the plate for about a minute. Right after turning off the blower, I took off the plate and pulled the suction cup with a cutter at hand. You’ll hear a bit of a cracking/popping noise when the adhesive is starting to give, just apply a little more force and push the cutter at the seam. This method worked great for me, so good luck and just keep at it — you’ve got this!
    Nicholas Weger - 回复
    I used nearly boiling water in a storage zip bag on the phone for 10 minutes. I can’t really recommend this method, but thankfully the bag did not leak - an iOpener is probably a much better way to go. Regardless, the bag covered the entire back of the phone, and the phone was too hot to hold, but I still could not get the glass to budge with the suction cup after struggling with it for about an hour and multiple reheats. I ended up epoxying a 2”x2” square of PVC board to the bottom of the cover and built a relatively complex fixture that pulled on the PVC with the turn of a screw while it held down the frame by the edges. After heating the edges up again It did lift the glass enough to get a pick underneath it, but it cracked the glass and it was a pain to slide a pick around the edge while the glass was cracking all the way around. Once I finally got all the glass off, I spent the next 30 minutes (which is what this entire process is supposed to take… what a joke!) cleaning the adhesive off the phone.
    drbenton815 - 回复
    Heavy Duty Heat Gun from popular discount tool store for the win!
    Jesse Meyer - 回复
    Well, it is not obvious how to do this. I have no iOpener, but a heat cushion for remedy hurting muscles and sometimes a backpain. It is filled with grain of some kind and it is to be heated in a microwave oven for about 3 minutes. After that I enveloped this cushion round the phone and brewed myself a cup of tea. After ten miutes the phone was warm (almost hot) and I was able to press the tip of a small (very small) knife above the charging port into the connection between the phone body and the backplate. A very small opening emerged slowly (this is the critical point in this process) and I was able to start using the iFixit opening picks. It became obvious to me that the opening picks are too blunt to achive this with them. But after starting carefully with the (very small and very sharp) knife, everything went straight forward. Thou I had to give the phone a second heatpush with my heat cushion before the backplate came loose.
    borutberg - 回复
    I used my 3D printer heat bed and heated it to 90 Celcius to succeed.
    gahute - 回复
    It took about 3 minutes on my 90 C printbed to get the first pick in. If the suction cup gives up before the adhesive does, try using some Isopropyl alcohol to clean the back of the phone, and it should stick better. Also, don't apply heat to the screen, just in case that wasn't clear.
    Evan Newman -
    Used a corn bag (usually used for sore muscles) and incased the phone. It was hot to the touch, but it did the trick. Also needed a knife to have a small enough edge to start prying the back off and get the adhesive to finally pop.
    Laurie Hallberg - 回复
    Don't Forget Step 0! Turn the phone Off and remove the SIM card tray. just to be safe, I'd recommend making a full backup of your phone onto a micro SD card in case the worst should happen. also, make sure anyone who needs to contact you knows you aren't currently available at your phone number.
    Evan Newman - 回复
    We went for a hairdryer. Put it on hot, low blow and put the head right up to the corner. Took maybe 5 minutes per corner!
    Robert Tomohamat - 回复
    Removing the back wasn't too difficult on my phone: several rounds of heating with the iOpener, applying gentle pressure with the suction cup, and eventually a corner lifted up without much force and I could easily slide a pick in. From there it was very straightforward and I had no trouble sliding the picks around and removing the back. The battery removal was much harder in comparison (especially as the iOpener burst when reheating in the microwave for the battery, despite following the time instructions).
    Less eWaste - 回复
  2. 三星 Galaxy S9 屏幕更换: 步骤 2 中的图像 1,1
    • 在以下步骤中,你将切割固定后盖的粘合剂。
    • 如图所示,后盖内侧的粘合剂是这样布置的。
    • 你将在所示区域中切割粘合剂:
    • 粘合剂厚的区域
    • 粘合剂薄的区域
    • 避免在此区域做撬动或滑动之类的操作,以保护指纹传感器柔性电缆。
    I ran into a chunk of adhesive that was in the red zone right next to where the connector was. Be careful, cut slow, I managed to make it through my working my way through things that felt like foam.
    Matthew Speltz - 回复
  3. 三星 Galaxy S9 屏幕更换: 步骤 3 中的图像 1,3 三星 Galaxy S9 屏幕更换: 步骤 3 中的图像 2,3 三星 Galaxy S9 屏幕更换: 步骤 3 中的图像 3,3
    • 如果手机的后玻璃破裂,吸盘可能不会粘住。尝试用强力胶带将其提起,或将吸盘加到适当位置并使其固化,以便继续进行。
    • 将吸盘按到后盖上。
    • 用吸盘提起后盖的底边,打开后盖和框架之间的微小间隙。
    • 这可能需要很大的力,但你只需要用吸盘打开一个非常小的间隙即可插入工具。如果遇到问题,请加热以进一步软化粘合剂,然后再试一次。粘合剂冷却速度非常快,因此你可能需要反复加热。
    • 在你打开的间隙中插入一个三角撬片,然后将其滑动到右下角。
    • 插入第二个三角撬片并将其滑动到左下角。
    • 插入第三个三角撬片,以防止粘合剂在其余的拆卸过程中重新密封。
    The manufacturer obviously doesn't want owners to replace the battery, or they would have a simple method like they did in the past !!! They would rather have you throw it away and replace the phone !!!!
    johnbriand3 - 回复
    Well. I guess so!
    I was so looking forward to doing this.
    What a shame this type of manufacturing occurs!
    From a do it yourself person.
    357CLOUDY Black Feather -
  4. 三星 Galaxy S9 屏幕更换: 步骤 4 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 4 中的图像 2,2
    • 在仅插入三角撬片的尖端时,将其从左下角沿侧面滑动到顶部。
    • 将三角撬片绕顶角滑动并将其留在那里以防止粘合剂重新密封。
  5. 三星 Galaxy S9 屏幕更换: 步骤 5 中的图像 1,3 三星 Galaxy S9 屏幕更换: 步骤 5 中的图像 2,3 三星 Galaxy S9 屏幕更换: 步骤 5 中的图像 3,3
    • 将三角撬片从右下角沿侧面滑动到顶部。
    • 如果粘合剂难以切割,请加热。在移除过程中,后盖始终处于张紧状态,如果粘合剂没有足够软化,则可能会破裂。
    • 滑动拐角处的三角撬片,并切断手机顶部的剩余粘合剂。
    • 不要一下子打开手机。易碎的指纹传感器电缆仍然将后盖连接到主板。
  6. 三星 Galaxy S9 屏幕更换: 步骤 6 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 6 中的图像 2,2
    • 小心抬起后玻璃侧面有音量按钮的位置。
    • 使用撬棒的边缘撬起并断开指纹传感器柔性电缆。
    Bij mij kwam de vingerafdruk sensor los van de glazen achterkant
    Thomas Apol - 回复
  7. 三星 Galaxy S9 屏幕更换: 步骤 7 中的图像 1,1
    • 取下后玻璃。
    • 重新组装时,请按照本指南更换粘合剂并重新安装后玻璃。
    • 如果你想要更换后玻璃,请按照本指南传送后部相机挡板,包括指纹。
  8. 三星 Galaxy S9 屏幕更换, NFC天线和无线充电线圈: 步骤 8 中的图像 1,1
    • 拧下八个4mm Philips #00螺丝。
    I think the #000 fits better!
    Robin Vasdev - 回复
    The second and fourth screws on the bottom row are a little shorter at 2mm ( I measure the others as 3mm). Worth some care to put the screws back in the same holes as they came from. (SM-G960U)
    Will Smart - 回复
    Hi Will,
    thank you for mentioning! On our model the “SM-G960XU” all screws have the same length (4 mm). However this might differ between different models and is definitely something to keep an eye on during repairs.
    Dominik Schnabelrauch -
  9. 三星 Galaxy S9 屏幕更换: 步骤 9 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 9 中的图像 2,2
    • 在包含NFC天线和无线充电线圈的塑料层的右侧底部插入撬片。
    • 稍微转动或者撬动以打开固定塑料层的弹性夹。
  10. 三星 Galaxy S9 屏幕更换: 步骤 10 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 10 中的图像 2,2
    • 在塑料层的左侧底部插入撬片。
  11. 三星 Galaxy S9 屏幕更换: 步骤 11 中的图像 1,1
    • 取下包含NFC天线和无线充电线圈的塑料层。
  12. 三星 Galaxy S9 屏幕更换, 断开电池: 步骤 12 中的图像 1,1
    • 使用撬棒的扁平一端来将电池的柔性排线从插座上断开。
  13. 三星 Galaxy S9 屏幕更换, 拧开主板盖: 步骤 13 中的图像 1,1
    • 卸下将塑料盖固定到位的两颗4毫米Phillips#00螺丝。
  14. 三星 Galaxy S9 屏幕更换, 移除主板盖: 步骤 14 中的图像 1,1
    • 从主板上卸下塑料盖。
  15. 三星 Galaxy S9 屏幕更换, 屏幕: 步骤 15 中的图像 1,2 三星 Galaxy S9 屏幕更换, 屏幕: 步骤 15 中的图像 2,2
    • 使用撬棒的平端断开显示器柔性电缆。
  16. 三星 Galaxy S9 屏幕更换: 步骤 16 中的图像 1,1
    • 准备 iOpener 并将其应用于显示器至少两分钟,以软化下面的粘合剂。
    • 你可能需要多次重新加热并重新应用iOpener 以使手机足够温暖。按照iOpener 说明操作以避免过热。
    • 如果你的显示器玻璃破裂,请保持进一步的破损,并在修理过程中通过粘贴玻璃来防止人身伤害。
    • 在显示器上放置重叠的透明包装带,直到整个面都被覆盖。
    • 这将保持玻璃碎片包含,并在撬起和提升显示器时提供结构完整性。
    • 戴上安全眼镜,以保护你的眼睛免受任何在维修过程中飞溅的玻璃。
  17. 三星 Galaxy S9 屏幕更换: 步骤 17 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 17 中的图像 2,2
    • 一旦屏幕摸起来变暖了,请在手机的上边缘使用吸盘。
    • 如果手机的屏幕破裂,吸盘可能不会粘住。尝试用强力胶带将其提起,或将吸盘加到适当位置并使其固化,以便继续操作。
    • 在间隙中插入一个三角撬片,然后将粘合剂滑动到左上角,开始切割粘合剂。
    use utility knife razor blade, works so much better
    Siarhei Seviaryn - 回复
  18. 三星 Galaxy S9 屏幕更换: 步骤 18 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 18 中的图像 2,2
    • 插入另一个三角撬片并将其滑动到手机的右上角。
    • 插入第三个三角撬片,以防止粘合剂在显示屏拆卸过程中重新粘合。
  19. 三星 Galaxy S9 屏幕更换: 步骤 19 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 19 中的图像 2,2
    • 开始将右侧三角撬片向下滑动到框架侧面的一半以切割粘合剂。
    • 如果切割变得太困难,请重新加热并重新使用 iOpener。
    • 将左边的三角撬片向下滑动到框架的一半,并将其留在原位。
  20. 三星 Galaxy S9 屏幕更换: 步骤 20 中的图像 1,3 三星 Galaxy S9 屏幕更换: 步骤 20 中的图像 2,3 三星 Galaxy S9 屏幕更换: 步骤 20 中的图像 3,3
    • 在框架的左侧插入第四个三角撬片,然后将其向下滑动到左下角以切割粘合剂。
    • 屏幕的柔性电缆位于靠近电源按钮的中点下方,可能会干扰你的切割工具。
    • 在右侧插入第五个三角撬片,并用它切割剩余的粘合剂。
  21. 三星 Galaxy S9 屏幕更换: 步骤 21 中的图像 1,2 三星 Galaxy S9 屏幕更换: 步骤 21 中的图像 2,2
    • 一旦在手机的所有侧面切割粘合剂,你可以慢慢向上提起显示器并将其取下。
    • 显示屏电缆穿过中框的孔;仔细拆开它以拆掉显示屏。
    • 在安装新显示屏之前,请从框架上取下所有残留的粘合剂,并用异丙醇(> 90%)和无绒布清洁粘合区域。
    • 如果框架弯曲,或者留下任何胶水或玻璃残留物,则新显示屏将无法正确安装并可能损坏。如有必要,请更换框架。
结论
将新的更换配件与原始配件进行比较 —— 在​​安装之前,你可能需要转移剩余配件或从新配件上移除粘合剂背衬。
确保新屏幕安全的最佳方法是使用一张定制的双面胶带。将胶带贴在屏幕背面,然后小心地将显示屏电缆穿过框架。对齐屏幕并将其按入到位。
要重新组装你的设备,请按相反顺序执行上述步骤。
如果可能,请在安装新胶粘剂并重新密封手机之前打开手机并测试维修。
将你的电子垃圾带到R2或e-Stewards认证的回收商
维修没有按计划进行?查看我们的Answers社区以获取故障排除帮助。
79等其他人完成本指南。
由衷感谢以下译者:
en zh
90%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
于11/23/16注册
230,442 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
118 名成员
创作了19,553篇指南
6条评论
Hi replaced the whole screen and frame but board is overheating?
colin - 回复
A bit of guidance on where the adhesive seal goes would be nice. I believe I got it right.
john bromm - 回复
digitizer is stuck to glass, and came apart
specializedber - 回复
I followed the entire guide and still got a black screen of death.
Andrew Haynes - 回复
Na het uitvoeren van alle stappen kwam ik een goudfolie tegen achter het scherm. Deze zie ik niet terug in jouw beschrijving. Wat kan ik doen?
Eurydice Wilsterman - 回复
After I replace the screen and lcd will everything still be on my phone? Contacts,pics,apps, pics etc.
Wayne K Davis - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 168
过去 30 天: 855
总计 174,974
