跳转到主内容
此翻译可能不反映源指南的最新更新。 帮助更新翻译查看源指南
一加 5T 扬声器更换
你所需要的
  1. 一加 5T 扬声器更换, 后盖: 步骤 1 中的图像 1,2 一加 5T 扬声器更换, 后盖: 步骤 1 中的图像 2,2
    • 开始之前,请关闭手机。
    • 卸下SIM卡托盘。
  2. 一加 5T 扬声器更换: 步骤 2 中的图像 1,1
    • 卸下两颗Torx T2螺钉(长度为2.5毫米)。
    • 一加 5T不需要使用很多粘合剂来固定底盖,但是夹扣非常坚固,在打开过程中需要一定的力。
    Could you clarify the statement “The OnePlus 5T doesn't use a lot of adhesive“? Do you mean that it uses adhesive, but only a little? Or do you mean that it doesn’t use any adhesive at all to secure the back, just the clamps?
    Avram Grumer - 回复
    Hi Avram,
    there is a little bit of adhesive underneath the edges of the back cover, however it doesn’t require heating to soften it. In case the back cover doesn’t come of straight away it won’t help to apply an iOpener to further soften the adhesive but requires a little bit more force to open the plastic clamps.
    Dominik Schnabelrauch -
    i have tried t2 srewdrivers multiple times but they doesn’t seem work, could those be different screws?
    Mr Kono - 回复
    I had the same problem. I tried a T1 screwdriver, that fit perfectly.
    That said, the 'tools' section of this repair doesn't mention any torx screwdriver. That should be updated to include the T2 (or T1, for me!) screwdriver.
    Akka -
    I purchased the entire kit to do my battery replacement and found the opening tool was not capable of opening my One Plus 5t phone. I tried the tool for at least 30 minutes and couldn’t even get it started. Luckily I had a set of “plastic tools” for removing door panels from cars while doing stereo work. These tools have nice sharp points and are much longer and thicker, providing much better grip and leverage. With these tools, I had the back off the phone in just a few minutes. All the rest of the process was easy to follow and everything worked out great.
    David Dery - 回复
    I have all of the necessary parts/tools for replacement. Upon removing the two screws from the bottom, one came out no problem first try. The second bolt slipped andbis now completely stripped out. Any advice?
    Derek Basham - 回复
  3. 一加 5T 扬声器更换: 步骤 3 中的图像 1,3 一加 5T 扬声器更换: 步骤 3 中的图像 2,3 一加 5T 扬声器更换: 步骤 3 中的图像 3,3
    • 在显示屏和手机底端的后盖之间插入打开工具。
    • 使用打开工具在后盖和显示屏之间形成间隙。
    • 在用开口工具创建的间隙中插入三角撬片。
    Don’t make the same mistake as i did and put the opening tool between the screen and glass rather than the screen and body. Make sure its the second line from the top where you insert your tool
    Hayden Rooney - 回复
    This part is very difficult, i have been trying to open the phone up, still cannot.
    Taz - 回复
    The easiest way to open the back cover, is by starting from the bottom right corner, try find a plastic tool that is slim enough to go through the display and back cover.
    Taz - 回复
    I too had troubles with this step. I recommend having a look at the guide for opening up the back cover of the Oneplus 5 before proceeding. It has a lot of helpful images and the instructions go into far more detail than this one does.
    一加5的后盖更换
    Iceblade02 - 回复
    This step was the hardest step for me. I could only succeed with suction cup pliers and a metal pry tool, which unfortunately scratched the device’s edges a little.
    Haggai Eran - 回复
    I found this hard. Look carefully and use a bright light. There are two small ridges. I worked ages on the top one which isn't actually a gap. You need to work on the bottom one of the two. I used a very small metal screw driver with a thin flat blade. I pushed this in to open the gap a fraction then put a plastic tool in the now slightly opened gap and worked it round.
    Duncan Putman - 回复
    For opening up the device, 一加5的后盖更换 that Iceblade02 mentions is excellent. The tools in the kit also correspond to it since the new kit that I received last week had no guitar picks and instead had the suction cup.
    Anirudh Ramanathan - 回复
    Be sure you are getting below the screen's LOWER lip, as in the photo, as HaydenRooney mentions.
    Try to minimize flexing of the screen when you are wedging, the clamps (like snaps or tabs) will demand force and you want to avoid turning that into screen flex. There are several forum posts here about device working-but-dark after a repair. Too bad user input is rather folded away on ifixit, and few will see these.
    Professor Z - 回复
  4. 一加 5T 扬声器更换: 步骤 4 中的图像 1,3 一加 5T 扬声器更换: 步骤 4 中的图像 2,3 一加 5T 扬声器更换: 步骤 4 中的图像 3,3
    • 将打开的三角撬片滑到手机的右下角。
    • 插入第二个三角撬片并将其滑动到手机的左下角。
  5. 一加 5T 扬声器更换: 步骤 5 中的图像 1,3 一加 5T 扬声器更换: 步骤 5 中的图像 2,3 一加 5T 扬声器更换: 步骤 5 中的图像 3,3
    • 沿左下角滑动三角撬片,然后沿手机的左边缘向上滑动,以打开用于固定后盖的塑料夹。
  6. 一加 5T 扬声器更换: 步骤 6 中的图像 1,3 一加 5T 扬声器更换: 步骤 6 中的图像 2,3 一加 5T 扬声器更换: 步骤 6 中的图像 3,3
    • 沿右下角滑动打开三角撬片,然后沿手机的右边缘向上滑动,以打开用于固定后盖的塑料夹。
  7. 一加 5T 扬声器更换: 步骤 7 中的图像 1,3 一加 5T 扬声器更换: 步骤 7 中的图像 2,3 一加 5T 扬声器更换: 步骤 7 中的图像 3,3
    • 尽量不要完全移除后盖。指纹、充电端口和耳机电缆仍然连接到主板。
    • 翻转手机,然后用力将底盖的底端从手机部件上抬起。将其向左折叠并以80°角保持。
  8. 一加 5T 扬声器更换: 步骤 8 中的图像 1,2 一加 5T 扬声器更换: 步骤 8 中的图像 2,2
    • 使用撬棒撬起并断开指纹柔性电缆。
  9. 一加 5T 扬声器更换: 步骤 9 中的图像 1,3 一加 5T 扬声器更换: 步骤 9 中的图像 2,3 一加 5T 扬声器更换: 步骤 9 中的图像 3,3
    • 将后盖旋转180°并放下,以将后盖的底端对准电池的顶部边缘。
  10. 一加 5T 扬声器更换: 步骤 10 中的图像 1,1
    • 卸下#00十字螺丝(2.8毫米长)。
  11. 一加 5T 扬声器更换: 步骤 11 中的图像 1,3 一加 5T 扬声器更换: 步骤 11 中的图像 2,3 一加 5T 扬声器更换: 步骤 11 中的图像 3,3
    • 使用镊子去除覆盖电池,充电端口和耳机插孔柔性电缆连接器的金属小屏蔽。
  12. 一加 5T 扬声器更换: 步骤 12 中的图像 1,2 一加 5T 扬声器更换: 步骤 12 中的图像 2,2
    • 使用撬棒撬起并断开充电端口和耳机插孔柔性电缆。
  13. 一加 5T 扬声器更换: 步骤 13 中的图像 1,2 一加 5T 扬声器更换: 步骤 13 中的图像 2,2
    • 卸下后盖。
  14. 一加 5T 扬声器更换, 断开电池: 步骤 14 中的图像 1,2 一加 5T 扬声器更换, 断开电池: 步骤 14 中的图像 2,2
    • 使用撬棒撬起并断开电池柔性电缆。
  15. 一加 5T 扬声器更换, 扬声器: 步骤 15 中的图像 1,1
    • 卸下六颗菲利普斯#00螺丝(2.9毫米长)。
  16. 一加 5T 扬声器更换: 步骤 16 中的图像 1,3 一加 5T 扬声器更换: 步骤 16 中的图像 2,3 一加 5T 扬声器更换: 步骤 16 中的图像 3,3
    • 将三角撬片滑到扬声器左侧下方。
    • 使用三角撬片撬起扬声器,使其脱离凹槽。
  17. 一加 5T 扬声器更换: 步骤 17 中的图像 1,2 一加 5T 扬声器更换: 步骤 17 中的图像 2,2
    • 移除扬声器。
结论
请按逆序重组你的设备。在使用酒精清洁相关区域后,请涂抹新的粘合剂。
请把电子废料带到 R2 或e-Stewards 认证的回收商
维修没有按计划进行?尝试 基本排障方法。或者咨询我们的论坛来寻求帮助。
2等其他人完成本指南。
由衷感谢以下译者:
en zh
87%
Yuting Zhao正在帮助我们修复这个世界! 您也想加入吗?
开始翻译 ›
于11/23/16注册
204,379 声望
创作了682篇指南
团队
iFixit iFixit 的会员
Staff
136 名成员
创作了17,299篇指南
2条评论
Following water damage the loudspeaker stopped working. I changed it out (twice) and the flex cable but still not working. Any ideas?
Daryl - 回复
did you ever find a solution to this issue?
Neil Kumaran -
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 43
总计 2,370
