简介
选择错误的螺丝刀刀头,有时意味着维修成功和维修困难之间的区别。遵循本指南中的提示,正确识别你的螺丝刀刀头,防止那些可悲的滑丝。
如果在查看此处的信息后仍然遇到麻烦,请查看这个超棒的指南,了解一些螺丝刀的使用技巧。
你所需要的
具有前缀“J”和“PH”的位通常被认为是相同的。 不要被他们相似的外表所愚弄 - 他们是完全不同的。
十字(PH)螺丝设计成使十字螺丝刀凸出,如果施加过大的扭矩。 这样可以防止损坏螺钉和螺丝刀或钻头。
日本工业标准(J)螺丝不凸出,并有90度角。
which is which? why not tag each with a label?
Japanese Industrial Standard (J) screws do not provide a cam-out option, and have 90 degree corners
Oscar -
Hiya, Alberto! Great question. Smaller screws found in electronics aren’t particularly durable, and using a Phillips screwdriver on a Japanese Industrial Standard screw head (or vice versa) can lead to some pretty major problems. I highly recommend using the proper screwdriver or bit to avoid stripping screws.
Richard -
Which one should I get in America for iPhone and laptop type repairs , PH or J?
According to JIS and ISO standard, both recess dimension seem to be the same, having a rounded corner between two flats. I think, the recess without rounded corners (as right drawing) is a recess of CIPA (older JCIS) standard. According to CIPA, the edge between two flats is R0.06mm rounded shape, which seems to be neary sharp edge. Anyway, CIPA is a Japanese Standard and used mainly for the screws of Japanese electrical instruments.
I have two Phillips heads, one is labelled PH.2, the other labeled SH.0.
The second one has a very snub nose, which is what I need for the screws I need to work on. The more pointed PH one is too loose as the point doesn't allow it to fully seat into the screw head.
A seemingly identical snub-nosed one from another set is labelled: CR-V3#, and another seeming clone as ACR-2..
I'm having a bit of confusion on how to buy another screw bit like I need.
I have the small screwdriver kit you make. (Forgot the name) There are J1 and PH1 drivers. However, apart from the stamped label, those two especially are identical. The J1 is as rounded as the PH1 and all angles and lengths are the same. (I looked closely with a good magnifying glass.)
There is a very visible difference between J0 and PH0. So I assume either my PH1 or my J1 has a manufacturing error.
Hi @glitchglitch, email support@ifixit.com to open a ticket.
Happy fixing!
Great guide, but i have a question about some other bits.
Is there a difference between the "Tri-wing" and "Tri-Point" there are two bits available at the store both designated "Y0" or are they interchangeable
147等其他人完成本指南。
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
18条评论
Excellent guide. could not figure out the difference by looking.
It would be clearer if the displayed drawing of each bit actually said J-bit or PH-bit, and because both have 90 degree corners, maybe change the J-bit description to “have 90 degree square inside corners“ and include in the PH description “have 90 degree rounded inside corners.
Otherwise, with interpretation, your article helped me.
what size hex shaft do these smaller bits have?. i have an electric precision screw driver, for electronics. i go through the PH1 bits very quickly. i can NOT find them for sale anywhere on earth. does anybody know where to purchase these things?? and/or tell me how i should word the query. all im getting is 1/4 hex shaft results. very frustrating
In the picture on the top of the page the bits with a 90° corner are marked as Phillips heads, the ones with the rounded corners are markes as JIS heads. But it seems to be the other way, as mentioned in Step 3 of this instruction, and also according to other pages like Phillips #000 Screwdriver
Sharp eye, Andreas! Thanks for catching that. We’ve updated the image at the top of the guide with the correct labels.
Right on the money there! 👍
i have just bought an ifixit kit, has some ph and j bits. I’ve looked at them under a microscope, compared angles, tried them on screws... i have found no difference whatsoever, they seem to be identical. What gives?
Hi @deepsoic, that’s a pretty interesting find you’ve made! Send an email over to our customer service team at support@ifixit.com and they’ll help you get this issue sorted.
The label indicating the drivers on the Mako 64-bit driver set is almost impossible to read (embossed black-on-black). You can print a better one from the diagram on the catalog page. See https://twitter.com/isonno/status/146455...
I got this set as a gift and I’m very disappointed it doesn’t include larger Phillips head bits. The largest in this set is too small for a lot of the screwheads on my electronics, especially since I’ve never seen some of these screwheads in my entire life. Do you have any larger Phillips bits for sale?
Probeer de volgende link eens: https://shop4fasteners.co.uk/blog/pozidr...
Misschien wordt het dan duidelijker.
I think the English information about jis may be wrong and outdated. I google Japanese,旧JISネジ vs iso ,Statement from Vessel,ねじにある丸い刻印「ISOマーク」 "point"screws are rare in Japan now. "point"means new jis/ISO(only M3/4/5) , "no point" is old jis in japan in 1960', The difference is the "screw pitch". and new JIS B 4633 screws also no point. only ISO 8764. You can test pb/wiha/wera/vessle with your jis screw, it won't make a difference.
sean zhang - 回复
What are philips #1,2 & 3 sizes? Are they different in thickness? Can Philips #1 Screwdriver be used on any Phillips screws?
Amit ghosh - 回复
A Phillips screwdriver has a head with pointed edges in the shape of a cross, which fits neatly into the cross slots of a Phillips screw. Phillips screwdrivers are available in five different sizes, from zero to four. If you don’t use the right size, you can easily strip a Phillips screw, making it difficult to remove.
Das sagt mir nicht welcher BIt für Kreutzschlitz 2,2- 3,5 mm ich benötige. Für mich völlig wertlos. Wird jetzt ein 000.00,0,oder 1,2, gebraucht?
