跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2375 个问题 查看全部
How to reduce 8+ gigabytes of yellow "other" in the capacity?
It's taking up a precious 8.8 of my 32 gigs. I have tried restoring (from a backup) to no avail. Restoring as a new phone would result in losing years worth of text message history. Please help! Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
Nathan, the storage capacity is probably at 8.8GB because of the stuff that you have on there for years. If you want to free up the memory, you have to move the stuff of your phone and onto a something more permanent. There is no way to free anything up if you do not move it off the phone. Time for some house cleaning :) Commercial software is available for doing this, like this one or you can try the trial version from here. Hope this helps, good luck
这个答案有帮助吗?
得分 2
添加一条评论
If the text messages are important to you, you should consider getting software that can copy them to your computer. After you do that, you can restore as new.
这个答案有帮助吗?
得分 1
添加一条评论
Go to the apps store and buy an app called sms export - downloads all your text msgs. needed my texts as evidence in court and i used it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Nathan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 4,217
