跳转到主内容
型号A1367,闪存容量:8、16、32及64GB
915 个问题 查看全部
Device is dead/will not Charge
Hi all.
Awhile back, my 4th generation, 8 GB iPod touch was exposed to a minor splash of water. The screen and the digitizer worked without any sign of malfunction as well as all the other parts, with one exception: the battery.
In detail, ever since the incident the device will not charge. I've tried plugging it into the computer as well as a USB wall charger. Neither approach will charge it.
At this time, the device's battery is completely dead. If I plug it into any power source, the charging screen appears (http://km.support.apple.com/library/APPL...) but nothing else will happen. Even if left for 48 hours plugged in, the device will not turn on.
Any idea what needs to be replaced? I'd assume it's the battery but then why couldn't it run off directly off of AC power from the wall?
Thanks in advance
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
最有帮助的答案
Jake Wimmer, it may do this because of a failure off the smart battery. Some of the idevices will not run unless they recognize a battery. Definitely start with a new battery. You also want to make sure that your dock connector is not shortened out, or shows any corrosion or debris. Start with a new battery and work from there. Make sure you clean the logic board with 90+% isopropyl alcohol to remove some of the water damage....
这个答案有帮助吗?
得分 1
添加一条评论
Thanks! Any recommendations on where to buy the battery from? Also, if the iPod is powered by a wall charger, is it still possible the dock connector would be somewhat shorted?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jake Wimmer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 1,099
