跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is a washing machine by Kenmore. It is identical to the Whirlpool Duet.
F 10 error code?
Turn on washer and water fills. then pump turns on for a second then stops and timer light begins to blink. Re tries itself three times before error comes on.
Have already cleaned....
1. Water inlet screens
2. Check ball under tub.
3. the screen before the pump.
Noticed there is some return coil with pump impeller on electric pump. Is this normal or is pump supposed to turn freely?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
Eric Tighe, The F10 error code is generated by the Motor Control Unit (MCU) Heat Sink Thermal Trip
If the thermal protector on the MCU heat sink gets too hot, it will open the thermal protector on the heat sink which will stop motor functions and an “F/10” will be displayed.
Potential Causes
• Check for Proper Installation, verify the unit is not located near a source of heat and has proper ventilation.
• Check Wire Harness connections to the MCU, the motor, and Central Control Unit (CCU)
• Check the Drive system for any worn or failed components
• Check MCU
• Check Motor
You can get the service manual for your washer from here.That should help you to check the individual components. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Eric Tighe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,480
