跳转到主内容
The BlackBerry Bold 9900 is a smartphone with full QWERTY keyboard and touchscreen.
25 个问题 查看全部
问题已关闭
Where to procure a "122" coil found on BlackBerry PCBs
Hello there,
a friends' Blackberry Bold 9900 is damaged and needs the "122 coil" replaced. It is used in other models as well, there is a similar question in the archives although unfortunately with no answer :(
I do hope that someone can help me
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Frank Frankly any chance you can post an image of where the coil is located? I do have the schematic as well as the logic board layout, but would need a better description of the location.
完成的
添加一条评论
1个答案
Frank Frankly, you may find them on Digikey.com or at Mouser.com. to figure out what you would need, follow this guideline."Values are in micro Henries (μH)
First two digits are the value
Third digit is the multiplier
If there is an R, its acts as a decimal point, and there is no multiplier
Examples:
101 = 10*10μH = 100μH
4R7 = 4.7μH " from here So yours should be a 1200µH coil. Also, coil is better found as an inductor when looking for it. Hope this helps, good luck.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,295
