Two quick tests tell you where the problem is before you buy any parts: do the low beams work, and does flash-to-pass work (pull the stalk toward you)?
If the brights flash when you pull the stalk but won't stay on when you push it forward:
- The multifunction switch — the turn signal stalk — is the prime suspect. On the 2004–2008 F-150s this switch is a known weak point; the internal contacts for the high-beam latch wear out while everything else on the stalk keeps working. Flash-to-pass uses a separate contact, which is why it still works.
- The switch is replaceable without pulling the steering wheel. Disconnect the battery, remove the screws under the steering column shroud, split the upper and lower shroud halves apart, and the switch is held by two screws with one electrical connector on the back. Unplug it, swap it, and test the brights before you put the shrouds back on.
- While you are in there, look at the connector — if any pin is discolored or the plastic is melted around it, the connector pigtail needs replacing too. The high-beam circuit runs through that switch, and heat damage at the plug is common once the contacts start going bad.
- Fitment note. A replacement multifunction switch commonly fits a 2004–2008 F-150 — always confirm against your vehicle's exact trim and engine and the product's fitment data before buying, since the switch varies with options like fog lights and the exact year.
If the brights don't work at all — no flash and no latch:
- Check the high-beam bulbs first. Pull one bulb and look at the filaments — the low-beam filament can be fine while the high-beam filament is burned out. Both sides going at once is unusual, but check both, and look for a corroded or melted socket while you are there.
- Check the fuse and relay for the high beams — your owner's manual shows which ones, in the fuse panel under the dash (central junction box). If there is an identical relay nearby, swap them as a test — if the brights come back, the relay was bad.
- If the bulbs, fuse, and relay are all good and the stalk still does nothing, the problem is in the wiring between the switch and the lamps or a bad ground — at that point you are tracing wires, and a wiring diagram for your year is worth having.
What to do: say whether the low beams work and whether flash-to-pass works — those two answers pin it down to the switch, the bulbs, or the fuse/relay. On these trucks, flash works but latch doesn't means the switch; nothing works at all means bulbs, fuse, and relay first.
Safety note: disconnect the battery and wait a few minutes before you take the column shrouds off — you are working right next to the airbag. If the switch doesn't fix it or you are not comfortable around the column, if unsure, consult a professional mechanic.
Disclosure: I used an AI tool to help draft this answer.
