跳转到主内容
加入维修社区 - 创建账户
2011 年 2 月发布的 1410 万像素相机,支持拍照和视频录制。现已停产。
Charge gets quickly exhausted
Whenever I turn the camera, after one or two image , the battery gets exhausted even
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I asked FixBot (Ai) your question with its reply in italics. Beware of Ai mistakes.
Rapid battery exhaustion on the Nikon Coolpix L120 is most commonly caused by an incorrect battery type setting, using standard alkaline batteries, or mixing battery ages and types.
Check and resolve the issue with these steps:
  1. Verify the Battery Type Setting: Press the MENU button, go to the Setup menu (☑), select Battery type, and ensure it matches the exact batteries currently in the camera (Alkaline, COOLPIX / Ni-MH, or Lithium) 1. If this setting doesn't match your batteries, the camera will misread the voltage drop and shut down prematurely.
  2. Upgrade to Ni-MH or Lithium Batteries: Standard alkaline AA batteries struggle with the high current demands of digital cameras (powering the LCD screen, zoom motor, and flash) and often drain after only a few shots. For best performance, use fresh AA lithium batteries or high-capacity Ni-MH rechargeable batteries (such as Nikon EN-MH2) 2.
  3. Avoid Mixing Batteries: Always replace all four batteries at the same time. Never mix old and new batteries, or combine different brands and chemistry types 3.
  4. Check Battery Contacts: Inspect the metal contacts inside the battery compartment for any dirt or corrosion, and wipe them clean with a dry cotton swab if necessary.
Sources:
123 Nikon COOLPIX L120 User Manual
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Hazelnut Eyes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 17
总计 17
