跳转到主内容
加入维修社区 - 创建账户
一款使用了多年,采用 R407 制冷剂的分体式空调设备。
Ac indoor display e1 error
My ac indoor display e1 error what happened is there any operation mistake or what how can repair
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I asked FixBot your question and its reply is in italics. FixBot AI can make mistakes. Verify critical details from reliable sources.
I [FixBot] couldn't find a specific troubleshooting guide for this exact error in iFixit's knowledge base, but information found elsewhere on the web indicates that an E1 error code on a split air conditioner typically points to one of a few common issues:
  • Temperature Sensor (Thermistor) Failure: The indoor room temperature sensor is disconnected, shorted, or faulty, preventing the control board from reading the ambient temperature.
  • Communication Fault: A loose, corroded, or damaged wiring connection between the indoor and outdoor units.
  • Control Board / Button Glitch: A temporary electronic latch or stuck button on the display panel requiring a system reset.
To troubleshoot, try cutting power to the air conditioner at the circuit breaker for 5 to 10 minutes to allow the control board to fully reset. If the error immediately returns, inspect the indoor unit's wiring connections and temperature sensor near the evaporator coil.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Suryakant Macwan 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 17
总计 17
