跳转到主内容
加入维修社区 - 创建账户
首次生产日期:2011 年 12 月 20 英寸 SyncMaster 显示器,分辨率为 1600 x 900。它还具备 Magic Angle(灵视角度)和 Magic Tune(灵调校)等选项。
How to turn on monitor
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hi,
First check that the monitor is plugged into a power source. Check that the cord is plugged in all of the way.
Locate the power button (it’s either a physical button or a touch sensitive icon located on the bottom right edge of the monitor bezel. Press it once to turn the monitor on. You should see an LED indicator light on the monitor change or turn off/on depending on its active state.
If the LED light is blinking, the monitor is in sleep mode. Move your mouse or press a key on your keyboard to wake it up.
If you have a message that says "Check Signal Cable," your monitor is receiving power, but needs an active input from your computer.
Hope this Helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Viola 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 36
总计 36
