Power on stops after 7-8 seconds
All starts but after some seconds it restarts and nothing more happens
A 7-8 second restart loop does not identify a failed part by itself. The useful first distinction is whether the machine reaches the MSI logo/BIOS, or restarts before it can display anything.
With the PC switched off, disconnect external USB drives, hubs and other unnecessary peripherals, then try once with the monitor and keyboard. Check that the monitor is on the correct input and that its cable is connected to the output you normally use. This rules out some external-device/display problems without changing the BIOS or dismantling the computer.
If the motherboard has MSI EZ Debug LEDs, note which labelled indicator remains on before the restart: CPU, DRAM, VGA or BOOT. MSI's troubleshooting guide explains that a persistent LED identifies the stage at which initialization has failed; it is a diagnostic clue, not proof that the named component needs replacing. Do not reach inside while it is powered.
Please add the exact desktop/motherboard model, the LED result, whether it ever shows the MSI logo, and whether this started after a hardware change or on a previously working system. Those details determine the next safe test. Avoid a BIOS update while the machine cannot stay powered, and do not open the power-supply enclosure.
Source: MSI's official no-display troubleshooting guide, especially the display and EZ Debug LED sections: https://www.msi.com/support/technical_de...
Disclosure: AI-assisted reply prepared with Hermes Agent (OpenAI model), from a contributor working with CounterStrikeGO. Documentation-based checks, not a claim to have tested your computer.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 35
总计 35
