How do I take these headphones apart?
I have a pair of Beats Pro by Dre. The wire that connects the left and right headphones is broken, causing only 1 side to work at once. I cant find how to take these apart anywhere, and I am having a very hard time figuring it out.
4条评论
Eric, is it on the 3.5mm plug or is it closer to the actual headphones?
由 oldturkey03 完成的
The 3.5mm plugs are fine. There is a plug on both sides, so whatever side the chord is plugged into works. The problem is the wire that runs through the band of the headphones and sends the audio to the opposite speaker.
由 Eric 完成的
Also have the same problem what can we do ! actaully was resorting to getting it fixed from a 3rd party but ive seen some recent bad reviews about it , how can i fix my beats !
由 tyler 完成的
I'm afraid I'm going to break them and will the foam go back on?!?!
由 Allie statham 完成的
