跳转到主内容
加入维修社区 - 创建账户
于 2021 年 9 月 24 日发布,iPhone 13 mini 是苹果 iPhone 13 的小型版本,也是第二款 mini 型号的 iPhone。它配备 5.4 英寸 OLED 屏幕、A15 Bionic 处理器以及后置双摄像头。
Changing Display and Proximity Sensor
Hi, I have rather a specific issue with this iPhone. It has been given to me as a second use phone and I decided to repair it. From my knowledge the display is a third party item (LCD I think), the touch is likely dead (unresponsive) I do not think something is wrong with the flex cable itself as it seems undamaged to me. And also the connector at the end of the flex cable for Proximity Sensor has 2 pins chipped off.
My question is. Is it worth it to try and bring to a working state? Would buying a new Proximity Sensor fix the unresponsive display? The FaceID?
Thanks for any reply.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
A new proximity sensor won’t fix an unresponsive touchscreen. The touch issue is more likely the third-party display, its flex cable, or the connector on the logic board. I’d test with a known-good compatible display first.
The damaged proximity sensor flex may affect proximity functions, and if the damage involves the original TrueDepth/Face ID components, Face ID may also be affected. Don’t replace those parts blindly; identify exactly which connector is damaged and test each issue separately before spending more money.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pracovny 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 58
总计 80
