跳转到主内容
加入维修社区 - 创建账户
2012 年发布,产品编号 #R675020。这是一款支持 WiFi 的自动吸尘器。
What does error 14 mean
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Error 14 on a 600-series Roomba (the 675 is one) is not a motor or battery fault. It means the robot does not see a bin installed: the bin-detect contacts are not completing the circuit.
In order:
1. Pull the bin out and reseat it, pressing down until it seats fully. A half-seated bin throws 14.
2. Clean the metal contact pads on the bin and the matching pads in the robot with rubbing alcohol on a Q-tip or rag, until they are bright and debris-free. Dust and pet hair on those pads is the usual cause (it is iRobot's own fix).
3. Inspect for corroded or bent contact pins. If a pad is damaged, the bin's contact strip is the failed part.
4. Still 14 with clean, seated contacts? Swap in a known-good bin. That tells you whether the bin's contact strip or the robot's contact board is the fault.
It is a $0 fix most of the time and you do not need to open the robot.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
denise mayes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 13
过去 30 天: 58
总计 82
