跳转到主内容
加入维修社区 - 创建账户
How to replace water pump
How to change water pump
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
On a Yaris, the water pump isn't the worst job in the world, but you don't want to rush it. Drain the coolant first, get the belt and whatever's blocking access out of the way, then you can remove the pump bolts and swap it out.
Clean the mating surface really well before putting the new pump in. A lot of people chase leaks later because they leave old gasket material behind or don't seat the new gasket properly. Fill it back up with the right coolant, bleed the air out, and run it while watching for leaks and checking the temperature.
I'd take a few pictures as you go too. Doesn't sound like a big deal until you've got three brackets and a belt sitting on the floor and you're trying to remember where everything went. I've seen plenty of simple repairs turn into a headache because somebody skipped that step.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Calvin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 37
总计 74
