跳转到主内容
加入维修社区 - 创建账户
饮水机的维修以及帮助指南。
Bottom loading water dispenser pump issue
I bought a brand new Hitachi bottom dispensing water cooler,
It has a sensor that indicates when the water jug is empty.
I have an issue that recently occurred which is that when then the water jug is empty, it seems to take in air along with the last drops of water and keeps the pump sucking air instead of turning off as it's supposed to.
It has happened two times and I have no clue how to troubleshoot it nor have I found any resources.
Update (10/03/26)
Update:
I removed all hoses, the bare pump still pumped dry so it has nothing to do with the hose system. I also completely emptied it of any water even from the drain pipe
The pump itself works fine
I also checked the floats and they seem to be in good order
If anyone has any idea on what it possibly is please tell me.
This is only the 4th cycle or jug and the first two were fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Hi @aliclay
What is the model number of the water dispenser?
由完成的
添加一条评论
1个答案
最有帮助的答案
Hi @aliclay
As you stated, no resources online.
If a user manual came with the dispenser, check if there's a troubleshooting section or perhaps the cleaning section in the manual to see if it mentions the problem or if the product has to be cleaned occasionally especially if it mentions cleaning a sensor window or suchlike.
Since it is brand new check the warranty information that is in the user manual or came with it as to how to contact the Hitachi customer service centre (or authorized repairer) in your location and ask them for a manufacturer's warranty repair or replacement.
Try not to disassemble the dispenser more than what is shown in the user guide so that you don't void the warranty.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Ali Clay 将永远感激不已
浏览统计数据:
过去 24 小时: 10
过去 7 天: 16
过去 30 天: 46
总计 46
