跳转到主内容
加入维修社区 - 创建账户
第 3 代 iPhone SE 在苹果“高能传送”活动中于 3 月 8 日发布。它配备 A15 芯片和 4.7 英寸 LCD 显示屏,与其前代产品 iPhone SE 2020 相似。
NFC antenna does not work
Hi, I’ve had this issue going onto a year now. It started from when I took out the logic board the first time to swap the charging port.
Everything else works except the nfc antenna and the back camera. I’m unable to use wallet to pay for stuff and my back camera doesn’t work.
After about a year my housing breaks so I swap the housing with a preowned one from eBay. Zero brackets missing yet the problem persists. I don’t know much about how the antenna works but I do know that it has something to do with some screws. Perhaps I’ve mixed a couple up?
I did lose the screw under the WiFi antenna that is unthreaded partially. I replaced it with spare screw that fits snug. Maybe that’s causing it? But then again it was screwed in on the previous housing and the issue remained.
Any helps much appreciated. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Since both NFC and the rear camera stopped working after the first logic-board/charging-port repair, I’d suspect a connector, flex, grounding point, or board-level damage rather than the housing itself.
I’d retrace the original repair and check every connector and screw/grounding point, especially around the camera and NFC circuitry. If you can pull a panic log, an iPhone panic log analysis may also reveal a related hardware communication fault.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Neryk Hernandez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 43
过去 30 天: 43
All Time: 43
