跳转到主内容
加入维修社区 - 创建账户
于2001年9月发布,型号为:C21-0111。这款镜头取代了 Canon EF 70-200mm f/2.8L USM 镜头,增加了全新的影像稳定系统 (IS) 并改进了光学设计。
How to remove interior fungus...etc.
I'm looking for a step by step disassembly, cleaning (fungus and stuff)and reassembly. Anybody?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hey!
This is the same reason I took apart my 90-300mm lens, and I did end up cleaning all the gunk out. BUT - I would highly recommend going to a professional with this one, because this is a much more complicated lens. If you really do want to take it apart, I would do a quick Google search on disassembly, and then take it apart and clean it carefully with a microfiber cloth. Make sure to document which screws go where, and take pictures of each step and what you did. Good luck!
由完成的 分享
添加一条评论
1个答案
For fungus inside that lens, I’d be careful about a full DIY teardown because the optical groups need to go back in exactly the same orientation and spacing.
A safer starting point is to remove the rear mount and inspect where the fungus is located. If it’s on an accessible element, cleaning may be possible, but fungus between sealed optical groups usually calls for a lens technician.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kulajon 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 16
过去 30 天: 56
总计 91
